Latest Gremlin!
Old Jul 19, 2010 | 08:19 PM
krylon's Avatar
krylon
Latest Gremlin!
I replaced a parking lamp socket that was out of order today. All my parking lights work, my hazards function as they should, however my turn signals are now non-operative. When the hazards are functioning they click as they should. But when I use my turn signals, there is no click, and no lights. Could this be a fuse? Any other ideas? Thanks in advance!
Old Jul 19, 2010 | 08:52 PM
tabascom16's Avatar
tabascom16
Might be that you dont have a good enough ground to the frame. I had the problem with the turn signals in the past and maybe some other lights and I did not have a good enough ground from the bed to the frame so ran a wire down to the frame and ground off the rust to get good metal to metal contact. You might be having the same problem.
Old Jul 19, 2010 | 08:59 PM
krylon's Avatar
krylon
I need to learn to use the search function before I post lol. I found out there are separete fuses for the hazards and turn signals. Problem solved, thanks for the reply though!
