Vacuum reservoir
Old Jul 19, 2010 | 12:49 PM
704 dentside man's Avatar
704 dentside man
Vacuum reservoir
I have a rig that has had all the emissions stuff pulled from it, except the vacuum reservoir (the big soup can) on the inner fender. I'm not entirely sure where the line leads to...and suggestions (intake)? The reason I ask is because I recently developed a pretty severe vacuum leak, I popped the hood and I saw a gash in that can. So seeing as everything else is gone, I should have no need for this, correct? So I should be able to just yank it out and cap where ever it leads, correct? Thanks
Old Jul 19, 2010 | 01:03 PM
tinaheels's Avatar
tinaheels
the vacuum reservoir is for the a/c controls
Old Jul 19, 2010 | 01:13 PM
704 dentside man
Oh ok...I was just looking through some catalogs and the reservoir was lumped in with the emissions stuff, so I assumed...and you know what that does. So if this acquires a gash, it can still cause a terrible vacuum leak and make the rig run like crap?
Old Jul 19, 2010 | 01:38 PM
tinaheels's Avatar
tinaheels
you could try to repair it with expoxy
Old Jul 19, 2010 | 02:30 PM
704 dentside man
Yeah...I was thinking of going that route. However, the A/C stuff is removed, so all I have is heat, can this reservoir be removed with no ill effects?
Old Jul 19, 2010 | 03:57 PM
hasteranger's Avatar
hasteranger
there is normally another resevoir over on the drivers side fenderwell for vaccuum purposes, the big one by the battery tray is for the AC, as mentioned. I've unhooked mine with no ill effects. Just tee the hose back to itself or block it off somehow, if youre not using your AC.
Old Jul 19, 2010 | 04:06 PM
704 dentside man
That's the one I'm talking about. I didn't realize there were so many vacuum reservoirs. Sorry for being unclear. But yes, the one on the driver's side is the one that has a a big gash in it. So now I'm back to, can I unplug and where does it go? Thanks.
Old Jul 20, 2010 | 08:44 AM
fmc400's Avatar
fmc400
MSEE
The purpose of the vacuum reservoir is to keep the heater/AC controls from letting go at low vacuum, such as at WOT.
Without the can, it's possible that the plenum won't be able to route the air properly if you're moving fast on the highway. You won't see any effects at idle, since vacuum is high then.
Old Jul 20, 2010 | 09:03 AM
704 dentside man
Thanks FMC. I think I'll give that JB Weld putty a try first, then rip it out if need be.
I do have a question though, in my search for a replacement, be it reproduction, junk yard or parts trucks...I saw a couple difference variations. I saw the can like I have, I saw the short can, but then I also saw a can that looked like mine, but it had 3 hose inputs, where mine only has one line going to it. Anyone know the difference? And could I replace my big reservoir with one of the shorter/stubbier reservoirs?
Old Jul 20, 2010 | 10:02 AM
hasteranger
you could solder your lid to a coffe can. thats basically whats under there. Or you could use any container that will hold vaccuum. It doesn't matter.
MI Yeti
WTB - Parts & other
May 9, 2017 08:19 PM
66with352
1997 - 2003 F150
Apr 3, 2017 12:53 PM
masonp
Jul 21, 2016 07:57 AM
Don Roberts
Apr 18, 2016 05:54 AM
Mccafiv8168
Apr 9, 2016 10:46 AM
