is it 360 or a 390?? HELP
Old Jul 18, 2010 | 11:16 PM
79 f-150 guy's Avatar
79 f-150 guy
ok so i pulled the engine from my parts truck to rebuild it.. i was tod it was a 390 but the truck decodes as a 360 truck.. i have here torn down and want to know what i have, i can see the heads were off once and changed so i'd also like to know if they are good heads or just run of the mill 2v stuff.. does anyone know where i can decode the casting #'s?? or maybe there is a way to tell what i got some other way?? thanks
Old Jul 18, 2010 | 11:23 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Casting numbers are more or less meaningless for FE engines...
Quickest way to tell with the engine pulled is the crankshaft flange... A square notch is a 390, half-moon shape is 360.
Josh
Old Jul 18, 2010 | 11:24 PM
montana_highboy's Avatar
montana_highboy
Measure the stroke....
3.78"=390
3.50"=360
Bullitt390's Avatar
Bullitt390
There are no differences between 360 and 390 truck heads either. And no such moniker has 2V heads or 4V heads like the Cleveland engine family.
Josh
Old Jul 18, 2010 | 11:34 PM
FLATFORD1976's Avatar
FLATFORD1976
390 came stock with a 4bbl Carb. I don't know if that helps but just sayin.
Old Jul 18, 2010 | 11:39 PM
79 f-150 guy
Josh
what flange are you talking about?? i'll go out to the garage and check quick as soon as i know what flange you mean..
Old Jul 18, 2010 | 11:40 PM
Bullitt390's Avatar
Bullitt390
Very few Truck 390 engines came with 4 barrels and "stock" was the Motorcraft 2 barrel, you had to option up to the 4 barrel and not a single 360 came with a 4 barrel.
And only 4X4s came with a 2 barrel 360, not a single 390 was EVER installed in ANY 4 wheel drive trucks.
Josh
Old Jul 18, 2010 | 11:41 PM
Bullitt390's Avatar
Bullitt390
The rear crank flange with the flexplate/ flywheel removed. There will either be a square notch or half-moon crescent on the flange.
Josh
Old Jul 18, 2010 | 11:51 PM
79 f-150 guy
ok i'll run out to the garage and see what i can see..
Old Jul 19, 2010 | 12:03 AM
79 f-150 guy
ok it is a half moon. wich tells me it is a lowsy rotten 360, is that for SURE or 99% for sure....
also if you can help me on the heads, they have a casting # of C8AEH, are these 360 or 390 heads and are they anything specail or just run of the mill.. i can see they were changed in the past or removed and rebuilt.. thanks
Old Jul 19, 2010 | 12:22 AM
Bullitt390's Avatar
Bullitt390
C8AE-H heads are perfectly fine for a mild engine build. They were also used on 360, 390 car and truck and standard 428 engines.
390 GT heads are the same with different exhaust bolt drillings.
The half moon is 100% 352/360
Josh
Old Jul 19, 2010 | 12:27 AM
79 f-150 guy
ok thanks for the help, geuss i'm building a 360.. i plan on a stock rebuild with a 4v setup, msd ignition and long tube headers.. are there any other relitivly cheap mods i can do to get some extra poneys.. this is my first fe, i am a sb guy.
Old Jul 19, 2010 | 12:43 AM
mrcman58's Avatar
mrcman58
look at the bottom of the pistons, the 360 and the 390 have the same bore, 4.05 but the bottom of a 360 piston is skirted, the 390 piston is not fully skirted to allow for the extra stroke. you can make that 360 into a 390 by obtaining the crank, rods and a set of pistons for the 390, the blocks are the same.
Old Jul 19, 2010 | 02:51 AM
montana_highboy
That much is true.
Old Sep 7, 2019 | 05:08 PM
fast68's Avatar
fast68
totally wrong. either none were 4bbl or there was no 4bbl ones until ariound 75 76 when igniition was changed to DS II. before that all 390 truck were 2bbl. heres my 73 390. why do ppl feel the need to post incorrect info and eff ppl up.. hmm..
