Offroad & 4x4
Trac bar
Old Jul 25, 2010 | 09:16 PM
  #31
wyoming4x4's Avatar
wyoming4x4
The trick is!!
Keep it in line with driveshaft! When you get up/down travel make sure your axle wrap bar/gadget doesn't cause premature binding due to weird travel in suspension. binding in yokes and universal clearance issues. sometime in extreme situations weird spline movement in driveline if done improperly. Things to consider.
Old Jul 25, 2010 | 09:21 PM
  #32
73 ford guy's Avatar
73 ford guy
like I said before Im going to play around with a longer set of shackles to level it out more ,more level to d-saft. But as of now its 4 degrees off.
Old Jul 25, 2010 | 09:47 PM
  #33
ford12508's Avatar
ford12508
Can I just input 1 thing...ITS NOT A TRACBAR, TRACKBAR, TRAC-BAR, or any other variation of the name, it is a ladder bar, completely different!
Trac Bar keeps the axle from going side to side, Ladder bar does also, but not nearly in the same way, and thats not the main purpose of a ladder bar in most instances.
Old Jul 25, 2010 | 10:14 PM
  #34
73 ford guy
we've been over that. I then said, ok then "traction bar" thats whats its doing and I shortened it so w/e..LADDERBAR who cares
Old Jul 27, 2010 | 02:29 PM
  #35
alpha/omega's Avatar
alpha/omega
I never said it wouldnt work in any situation.
I said it wouldnt work on a 79 F250 with 4" of lift with the stock steering box in the stock location.
It is impossible with my current setup.
Youve got a homo-ghey amount of lift and thus have a metric ****ton of room between your axle and frame/steering box.
Old Jul 28, 2010 | 09:10 AM
  #36
alpha/omega
Lets see this highsteer setup
Old Jul 28, 2010 | 04:01 PM
  #37
73 ford guy
OK
O and as you say Uber gey homo lift!
this was taken today.
This is my twin bro in the pic and its his truck we built with pretty much all the same stuff as mine like 1 tons,4 wheel discs with hydro boost,hydro assist with high steer,all 1350 driveshafts, roll cage,power windows, new superduty seats and so on...
I'll admit this one is too big but its now on the road and its so much fun to bomb around in! Everyone yells out stuff constantly and gives thumbs ups. But its homo gey..
Old Jul 28, 2010 | 04:30 PM
  #38
kjett's Avatar
kjett
Wow if he ever took that thing off road, the 1st thing to get ripped off would be those step ladders he bolted to the floor pans. But by seeing how clean it is I can tell it's just a pavement pounding mall crawler.
Old Jul 28, 2010 | 04:31 PM
  #39
captain p4's Avatar
captain p4
Gotta admit it's a nice looking truck though. And teh truck isn't 3ft above the tops of the tires like those ghey floriduh trucks.
Old Jul 28, 2010 | 04:49 PM
  #40
73 ford guy
Its a cool truck and its built to the **** with nice stuff. Yeah its not ideal by any means but like I said its fun to cruise in. As for ladders they're pretty slick actually. They swing up underneath and latch to the frame. Connected to the latch is a thin cable running down a tiny pulley out through the bottom corner of door that is nearly impossible to see so when the door is opened about 7/8 of the way it pulls the lever and it swings down nicely locking it in. everything is homebrew except the hinges
Old Jul 28, 2010 | 05:08 PM
  #41
73 ford guy
heres a couple more....
my neice decided to pose as I took pics..lol
O those checkerplate flares are on sliders. right now they are all the way in but they slide out to cover the whole tire. They will be hooked up on a electric actuator rod to control from cab soon. He's building the front ones right now then we're going to town to the beer store,then to the lake.
bad pic but interior is just as nice as outside. It just missing the gauge surround as of now
Old Jul 28, 2010 | 05:09 PM
  #42
captain p4's Avatar
captain p4
Are those the 49" Irocs?
Old Jul 28, 2010 | 05:19 PM
  #43
73 ford guy
yeah. He got them a year ago with 90/95% tred for $2000 CND. I ran them on my truck and they run Very smooth surprisingly even with no internal balancing. Front ones run a 2.5" wheel spacer so the thing is driveable. Otherwise it hits the leaf pack pretty good. Steering and brakes are not a problem after the upgrades. It drives nice. Its nice to see this thing move after sitting at my house for over a year. All it needed was brakes bled and a coil. My bro is just a lazy *** and put it off until last weekend..
Old Jul 28, 2010 | 05:32 PM
  #44
quadzjr's Avatar
quadzjr
just another Rockwell looser
poor axles....
Old Jul 28, 2010 | 05:33 PM
  #45
captain p4's Avatar
captain p4
Probably not an issue for a pavement pounder.. not all that much bigger than a 44.
