Offroad & 4x4
Trac bar
Old Jul 20, 2010 | 07:28 AM
73 ford guy's Avatar
73 ford guy
Originally Posted by Bender99
Dont you think the angle is a little steep to let your springs go to work? The way I see it in my mind it looks like a bad design. Let us know how well it works
It runs a little steeper than the driveshaft angle and the tube extendind forward makes the angle less and extends the length of the bar itself. I'm planning on experimenting with longer shackle sizes to see what happens. These are 7 1/4 . I'm going to make a set of 9 1/4's as well and it will lower angle just to see if it is any different.
Old Jul 20, 2010 | 07:48 AM
73 ford guy
I weld diff housings with mild steel filler. I dont believe nickle rod has any business on an axle housing. It's not grey cast it's ductile (nodular iron) and mild steel works great as long as you pre and post heat correctly. Keeping the different cooling rates of both metals in check, this is where people run into problems.
I work in a steel shop and my experience with welding to pots with cast rod has been with high steer hydro assist tabs, and 14 bolt tubes to pot with good success so something must be working.
Old Jul 21, 2010 | 03:43 AM
Bender99's Avatar
Bender99
It's just the tensil strength of the nickle rod that give's me worries.
Old Jul 21, 2010 | 07:21 AM
quadzjr's Avatar
quadzjr
just another Rockwell looser
Originally Posted by kjett
Fixed it for ya.
i've been workin on it some recently.....it's all but done.
-rear brake lines
-put wheels/tires on
-hydro-assist steering
Old Jul 21, 2010 | 07:28 AM
quadzjr's Avatar
quadzjr
it is a good design. Thats the point of the shackle so it doesn't bind w/ the motion that the leaf spring shackle/axle.....It doesn't matter much how steep it is to an extent.
Old Jul 21, 2010 | 11:15 AM
73 ford guy
Only other design I would of went with would of been a slip tube on the top end with a smaller pipe fitting in snug to the larger one. It would still allow twist and compression and extension for suspension movement..
Old Jul 21, 2010 | 12:28 PM
quadzjr's Avatar
quadzjr
That was the design i was orignally going to go with mainly b/c its unique but it would have to greased often to keep dirt/mud between the tubes and seizing or rusting together when it sits......if you dont take your rig in the mud it would be a fine option.
Old Jul 21, 2010 | 02:12 PM
Bender99's Avatar
Bender99
Still to steep, it doesn't seem like there is enough shackle there to keep the traction bar from trying to push the axle rearward on compression. 7 degrees is what ive heard is yummy.
Old Jul 21, 2010 | 04:01 PM
73 ford guy
7 degrees on what a smart car! I'm running 15 "s of lift . I'd think close to whatever your driveshaft angle is good enough. I went with a happy medium to try to gain as much ground clearance as possible from obsticles.
By the way heres a pic from yesterday...
I got 90% of it together now. Most of the little tedious things are out of the way and its basically down to the motor which is in the shop now just waiting on a shipment of pistons early next week! Paint will be within a month or 2. Priority is getting it up and running...
Old Jul 21, 2010 | 04:51 PM
quadzjr's Avatar
quadzjr
i disagree, remember the axle is moving backward some w/ the swing of the leaf spring shackle, not just pushing the front mount of the traction bar forward.
besides, look at those effing leaf springs, i dont think he's go to worry about too much flex.
post the length of the traction bar and both shackles and i'll tell you if it will bind, maybe i'm wrong and you need a longer shackle.....but i doubt it.
Old Jul 22, 2010 | 04:18 AM
Bender99's Avatar
Bender99
Yeah some, that's where the 7 degrees of an upward angle comes in, not a 45. Theres is no way that that shackle on the traction bar can move far enough forward or backward to stay in the same swing that the axle does, leafs are gonna bind. But with it being close to the center of the axle there might not be more then a couple inches of up and down travel so it just might be ok.
Old Jul 22, 2010 | 08:01 AM
73 ford guy
I'm guessing as of now it runs just over 30 degrees. My driveshaft is at 21 and it's just steeper. I'll throw my angle finder on it but it's not a 45...
Old Jul 22, 2010 | 04:24 PM
  #28
quadzjr's Avatar
quadzjr
........blah blah.........
look at his springs.....they aren't going to compress enough to bind (if its even possible). With those damn things i'm surprised he even has wheel hop/axle wrap.
but like i said, send me some measurements and i'll tell you if it will bind if your worried about it.
Old Jul 22, 2010 | 05:00 PM
  #29
73 ford guy
So the angle isn't even as steep as I thought it was it runs at 24 degress and driveshaft is actually 20. The length of top bar is 39 "s center to center of bolts...
Old Jul 22, 2010 | 08:05 PM
  #30
quadzjr's Avatar
quadzjr
just taking in account the axle moving vertical (not with the backward leaf spring shackle movement) the axle will only push the traction bar 3.4" forward if you somehow flex it enough to make that bar flat (which would never happen). That would easily be taken up by the shackle, and that is the absolutely worst condition (b/c i'm not at work with a computer, thats not taking the swing of the shackles in account.)
