Ok picked up a 94 turbo diesel truck for my son. got it real cheap because the tranny will not do anything. no reverse or forward gears, the od light goes on and off. I'm a std tranny guy so i have no clue and would appreciate any answers or where to start looking to fix the issue.. It has fluid and its not burnt nor does it smell burnt. The guy i got it from said it just would go one day. Thanks for any help
Check and see what codes it has Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
Actualy it probly needs a trans because even with out the electronics you should have second and fourth and revers. I'm asuming you checked the fluid what did it look like? also check to see if the shift selector cable is hooked up and moving the arm.
so i need a code reader to pull the codes, its the normal color that it should be, yes the cable is hooked up. what is the electrical thing on the shifter on the tranny?
That tells the trans computer what gear you have it in. It's possible those contacts are dirty or the wiring or unit is just bad. It's a relatively cheap part to replace. The code reader should tell you if it's bad.
The lack of reverse or any forward gears makes it look like a problem with either the torque converter or the pump. OR, is it a 4X4? May just be a problem with the transfer case.
