Knocking noise from the heads
Old Jul 18, 2010 | 05:01 PM
melvis's Avatar
melvis
OK so I've been having this glow plug issue and reading here about changing out the controller.
I wanted to do a test, and used a jumper wire to keep the glow plugs on longer than the 2 seconds it comes on and cuts off..
When I get in the truck it starts but has a BAD KNOCKING SOUND from the front left cylinders, like something is hitting the valves or the heads??
it used to knock some there when it was cold, but would stop when it warmed up.
THIS IS BAD. Could the glow plug have warped the head? or made a valve stick?>?
I havent' driven but a mile and decided I was going to damage something and turned around and came home.
I'm going to take that front left glow plug out and look at it when the engine cools.
Could I have warped something> I kept the glow plugs on to the count of ten ( with the jumper wire )
I have a manual pushbutton on one of my other diesels and 10 seconds is not too long on that engine.
I'm thinking I could take it to the shop tomorrow.
There is one other thought. I did have the air filter off and was crawling all over the motor to get to the Glow Plug controller. Maybe something fell out of my pocket like a pennY> I am not saying I heard anything, just trying to think what in the hell could be down in the cylinder making that bad knocking sound.
Could it be a sticking valve>?
Old Jul 18, 2010 | 05:06 PM
melvis's Avatar
melvis
I read on another forum that maybe a glow plug tip had broken off and was on the top of the motor>? I plan to pull the glow plugs and look at them when the engine cools down.
Old Jul 18, 2010 | 05:09 PM
Rick Wallace's Avatar
Rick Wallace
This is very likely,what kind of Glow Plugs are they?? [brand]
Old Jul 18, 2010 | 05:40 PM
melvis's Avatar
melvis
Autolite
autolite? they are brand new. I just installed them. I'm going to take them out and see if they came apart.
Old Jul 18, 2010 | 05:51 PM
kenpobuck's Avatar
kenpobuck
Motorcraft/beruglow plugs only! Those other brands Autolite,bosch etc are just plain junk. Becareful pulling them out as they may have swelled up if any burnt. And yes they will burn that fast lol.
Old Jul 18, 2010 | 05:52 PM
Rick Wallace
UH-OH,, You may have heated them to long,when you get them out if they are not burned or broken,go get motorcraft beruos, if one is broken,,,prepare to pull heads,,sorry,I know you dont want to hear that....
Old Jul 18, 2010 | 06:00 PM
melvis's Avatar
melvis
broken at the tip
OK so I pulled the glow plug and sure enough it's broken off at the tip. probably an 1/8 of an inch/
So I'm guessing I'm gonna probably have to pull the heads? maybe replace the piston? what would make it break off like that? too hot? how can that be?
These are brand new autolite glow plugs. Should I replace them with Navistar or Motorcraft?
Will this happen to my others?
Old Jul 18, 2010 | 06:02 PM
melvis's Avatar
melvis
no way they could have heated to long, it was only ten seconds.
what was the other brand? beruglow? I pulled a few of the others and they were fine.
these are all less that a week old.
Old Jul 18, 2010 | 06:05 PM
Rick Wallace
That is your knock,dont run it any more,yes the head will have to come off,{might as well do both} Depends how much the piston is damaged. MOTORCRAFT BERUO !! GPs Autolites are junk.........
Old Jul 18, 2010 | 06:06 PM
Rick Wallace
Does anyone remember where that bench test is where the gp burnt in 8 sec?? I cant remember where it is.....
Old Jul 18, 2010 | 06:08 PM
melvis's Avatar
melvis
So the mechanic is about 3 miles up the road. I probably should not drive it there right>? I should have it towed? I've run it less than 5 minutes. Reckon it ruined the piston too>? heads?
Old Jul 18, 2010 | 06:10 PM
Rick Wallace
Maybe ,maybe not on the piston,Tow it,dont drive it or you will ruin that piston for sure.[Ask me how I know?]
Old Jul 18, 2010 | 06:11 PM
melvis's Avatar
melvis
I've got a glow plug tester and I'm going to test
any that I get in the future.
This sucks big time. I guess I'm going to have to ride my motorcycle to work until this gets fixed.
question, why would I want to do both sides? the truck uses no oil, only has 120k miles on it.
Shouldn't I be able to just fix this one side>?
Old Jul 18, 2010 | 06:13 PM
Rick Wallace
Somebody jump in ! I want more than my opinion out there !
Old Jul 18, 2010 | 06:14 PM
melvis's Avatar
melvis
you've obviously had the same thing happen with the autolites?
I'm going to go ahead and order some motorcraft berus??
online I've found them for 12 bucks each.
Does NAPA carry them>? what about Navistar ( since this is an IH engine? )
