Trac bar removal?
Old Jul 18, 2010 | 02:35 PM
KRDiesel's Avatar
KRDiesel
Arrow Trac bar removal?
I just got the energy suspention kit. I need to remove the trac bar bolts. I can see that the nuts have a keeper so you have to remove the bolt. My 400 fp craftsman impact will not do anything. I have sprayed everything including my eyes with PB Blaster.
I was thinking about having the truck on the ground, puting a 30MM boxend on it and jacking up the boxend. Any other ideas?
Also it looks like you have to remove the bumper to pull the spring bushings??
BTW the kit is nice, but there are no directions, Just a parts list.
Old Jul 18, 2010 | 03:35 PM
cheezit's Avatar
cheezit
a bigger wrench works
Old Jul 18, 2010 | 03:40 PM
KRDiesel's Avatar
KRDiesel
What size to you recomend?
Old Jul 18, 2010 | 03:45 PM
cheezit's Avatar
cheezit
one about 3' long, use a 30mm scoket and brake over bar.
find a pipe that will fit over the end of what you are using to add leverage. becarfull you dont hurt something though.
Old Jul 18, 2010 | 04:05 PM
KRDiesel's Avatar
KRDiesel
ok, will try it, thanks!
Old Jul 18, 2010 | 04:46 PM
John Diem's Avatar
John Diem
If its safe use Heat if you have a set of torches.Dito what Cheezit said.
