Sponsored by: Real Truck
rear diff cover rusting out
Old Jul 18, 2010 | 10:44 AM
gene17847's Avatar
gene17847
hi folf i have a 2000 f350 drw 4x4 and my rear diff cover is rusted and leaking i need a new one but they ask for the ring gear size how do i find that out the door code is rc11 if that helps
Old Jul 18, 2010 | 11:17 AM
bpounds's Avatar
bpounds
Gene, check out this specification document for your truck:
https://www.fleet.ford.com/truckbbas...0/BBFSD00A.PDF
Your dually should have a Dana 80, and the ring gear is 11.25". The columns in the chart are hard to make sense of, but I believe that's what you've got.
Your "RC11" is not a code found in our chart. Here is the chart:
Ford Truck Enthusiasts Forums - View Single Post - Super Duty And Heavy Duty: ______SUPER DUTY Tech Folder_____
Using the codes possible for your truck, see if you can find your code. You probably want to know the ratio and whether you have LS or not, but it should not matter WRT the cover. I'm not sure why they are even asking. Knowing it was a dually F350 should have been all they needed to know.
My last piece of advice is to email Ed from his site, and ask him to look it up for you. Find PartsGuyEd here:
www.partsguyed.com
He will get you the right part at the right price.
Old Jul 18, 2010 | 11:19 AM
sammy77's Avatar
sammy77
On a diff cover bolt you should have a ID tag that will give you that info. I'm not sure why they would need that just for the cover...?
Old Jul 18, 2010 | 11:44 AM
bpounds's Avatar
bpounds
That's correct. This is just a case of a parts counter guy not knowing that a dually takes the large cover.
This page shows the two covers that apply to an F350. The small one is SRW, the large one is DRW.
www.partsguyed.com
You want the large one.
Old Jul 18, 2010 | 01:28 PM
gene17847's Avatar
gene17847
ok thanks for the help
Old Jul 18, 2010 | 01:32 PM
dkf's Avatar
dkf
I think you can get an OE Ford finned aluminum cover for the D80, I've seen them on new DRW trucks at the dealer.
