Cruise control
Old Jul 18, 2010 | 08:36 AM
Iceman_AKA_Ford guy's Avatar
Iceman_AKA_Ford guy
Cruise control
hey guys ive been trying to find out why my cruise wont work. how can i find if i have a vacuum leak? could it be a sensor? ive looked everywhere
Old Jul 18, 2010 | 08:42 AM
fordman1090's Avatar
fordman1090
Have you had the brake sensor recall done?
Mine stopped working for a while, then it was fine after i had the recall done.
It might be unlikely , but it could be a rather easy fix if all you have to do is take it to the dealer. Otherwise you'll have to start trouble shooting. And on a 93 there is no vac to the cruise. Its all electronic. It can be anything from the unit, to the speed sensor module, to the buttons on the steering wheel.
Old Jul 18, 2010 | 09:08 AM
quaddriver's Avatar
quaddriver
they do need vacuum and the line they feed on has a coffee can that might be holed (they rust) or the cable in the servo rusts and snaps, or the vss aint vss'ing, or the servo gizmos went bad, or the contacts in the steering wheel (if so equipped) went bad
