Whos got a shop manual? Help
07-17-2010, 10:34 AM
on
Can you give me the tightening sequence and torque spec for the upper and lower ball joints?
Thanks
1995 F250 4x4 5.8L Manual hubs
07-18-2010, 12:54 PM
on
Install the lower BJ stud nut using Loctite 242 and tighten to 35-40 ft lbs.
Tighten upper nut to 85-100 ft lbs and advance to line up the cotter pin.
Then go back to lower BJ and tighten to 95-110 ft lbs.
07-18-2010, 06:24 PM
on
Quote:
Originally Posted by
jplinville
Thank you fine sir.
1979 ,
1995 ,
1996 ,
2001 ,
ball ,
f250 ,
ford ,
joints ,
manual ,
manuals ,
repair ,
sequence ,
shop ,
tighting ,
truck
