Turbo cleaning
Old Jul 16, 2010 | 01:28 PM
mh5500's Avatar
mh5500
Turbo cleaning
Well I,m going to take my tubo back off and clean it. Will it come apart ok, or does it have to be pressed apart? Then whats the best way to clean it?
Old Jul 16, 2010 | 05:54 PM
brickie's Avatar
brickie
It will come apart with a little elbow grease a swing press and a chisel.3M pads and a die grinder will clean it up here is a link. Diesel Technician Society
Old Jul 16, 2010 | 06:53 PM
cheezit's Avatar
cheezit
really if you can get the turbo off then you should be able to clean it. the thing you need to do is mark the direction and location of the band clamps placement.
Old Jul 17, 2010 | 07:32 AM
npccpartsman's Avatar
npccpartsman
And it helps if you can take digital pictures during disassembly. A paint pen for marking the bands and clamps is invaluable IMHO.....or a center punch to mark the housings. It can take a little bit of force to get the exhaust side housing to separate and a deadblow/rubber hammer helps greatly with this so you don't crack the housing.
Mike-fire32
401, 477, & 534 SD Engines
Oct 13, 2018 06:55 PM
MagKarl
Feb 7, 2010 11:35 PM
k_conner
18
Jul 4, 2009 12:23 PM
dgparsons2
18
Jan 26, 2009 07:36 PM
