FUSE PROBLEMS
Old Jul 16, 2010 | 10:52 AM
MKWF25096's Avatar
MKWF25096
FUSE PROBLEMS
HI ALL, MY '96 F250 4X4 KEEPS BLOWING THE # 13 FUSE. I HEAR THAT IT CAN BE BRAKE LITE WIRING AND OR CHAFING UNDER THE CAB SOMEWHERE.IS THERE ANYTHING OR ANYPLACE ELSE I CAN LOOK FOR A PROBLEM? GONNA TRY AND TACKLE THE PROBLEM THIS WEEKEND. ANY HELP IS OF COURSE MUCH APPRECIATED. THX !!
Old Jul 17, 2010 | 12:12 PM
MKWF25096's Avatar
MKWF25096
THANKS FOR ALL YOUR EXPERT FRIGGIN HELP!!!!
Old Jul 17, 2010 | 12:37 PM
rla2005's Avatar
rla2005
Let me be the first to say welcome to the site. I will also let in on web etiquette: Turn off the caps lock key. Typing in all capital letters is consider as yelling and rude.
In reference to your demand for help I would say you are on the right track. Fuse 13 does supply power to the brake light circuit. It is going to take some circuit tracing to most likely find the problem.
Let me ask you this: Does the fuse blow upon inserting a good fuse or when you step on the brake pedal? Knowing this can help narrow down the search. I have seen a few rare instances of bulbs pulling too much current because the filament shorted to ground. If the bulb is blowing without ever pushing the brake pedal to apply power to the brake circuit you do most likely have a short to ground in the wiring from the fuse block to the brake light circuit.
Your second post on this site does not make you any friends anywhere in this type of forum. We can help you, so please curb your sarcasm.
Old Jul 17, 2010 | 01:16 PM
White 97 xlt's Avatar
White 97 xlt
You're quite welcome!!!!
Old Jul 17, 2010 | 01:45 PM
MKWF25096's Avatar
MKWF25096
thanks for your generous answer to my question. i leave caps on in my job so i sincerely apologise for offending the puter community.as to my problem, no it happens at random times, so i believe i'm on the right track, if it happened when i put the brakes on...uh i would know exactly where to look, i was looking for info as to any other place to ck. or of any other places that techs or others that have had the same experience have found the problem.since its 99 degrees here i was hoping to maybe cut my diagnosis time a lil'shorter.i have been doing this kind of work all my life, so i'm sorry if i led you to believe i am a beginner....thx anyway MIKE
Old Jul 17, 2010 | 02:09 PM
White 97 xlt
How about the trailer plug where it splits off in back, those things can be one heck of a mess sometimes.. ..
Old Jul 17, 2010 | 02:14 PM
MKWF25096's Avatar
MKWF25096
good idea, puttin it on my list....thx
WildF4u
Oct 20, 2014 09:50 AM
brkncly
6.4L Power Stroke Diesel
Sep 15, 2012 09:47 AM
Biggfoot
Dec 23, 2006 10:49 PM
nicko36
Aug 27, 2005 04:07 AM
kevchoate
Jan 31, 2005 05:03 PM
