Rear Main Seal?
Old Jul 22, 2010 | 01:08 PM
FarmerBill's Avatar
FarmerBill
no need to take the Rad off. Its not touching the pan. Also i don't think the lower rad hose will touch the pan either. So should be straight forward job far as the pan goes.
Old Oct 6, 2010 | 10:40 PM
parr4's Avatar
parr4
I'm about ready to do this job. Finally cool enough. One-piece FelPro OS34601R gasket. Use sealant any place on the block or pan? I'll remove the rings at the pan bolt-holes. Looks like I'll, at least, need to take the shroud off. FSM says to remove radiator? Jack at harmonic balancer? Thanks
Old Oct 6, 2010 | 11:40 PM
Dimitri.c's Avatar
Dimitri.c
I only had to pull the tranny backwards a few feet. Sounds easier to me than all the pan stuff. What is you year and model? What engine? I'm pretty sure the one piece seal only requires tranny removal though.
Dimitri
Old Oct 7, 2010 | 10:43 PM
Wyowanderer's Avatar
Wyowanderer
No need for any sealant, just make sure the pan and block are squeeky clean, especially around the rear main.
Take the shroud off, but leave the rad in place. You may need to take the rad hoses- keep an eye on them AND the rear of the valve cover while you're jacking the engine up at the balancer. BLOCK THE ENGINE UP between the motor mounts and the frame so it can't pinch you or fall down.
It should take a couple 2 X 4's.
Good luck.
Old Oct 7, 2010 | 11:02 PM
parr4's Avatar
parr4
Sqeeky clean. Will do. No sealant.
Hate to use balancer, but don't like using the pan at all and I sold my hoist.
Thanks Frank
Kapusta
Apr 15, 2020 04:32 PM
Jay Is Jay
Feb 22, 2017 01:14 PM
chapfr
6.7L Power Stroke Diesel
Dec 20, 2016 04:56 PM
F350GK
15
Sep 29, 2016 06:21 PM
Wheat.
Apr 30, 2016 01:18 AM
