Sponsored by: Auxito
how do u bled a proportioning valve
Old Jul 15, 2010 | 07:47 PM
muddiger99's Avatar
muddiger99
need help with brakes
<hr style="color: rgb(209, 209, 225); background-color: rgb(209, 209, 225);" size="1"> <!-- / icon and title --> <!-- message --> i just went and put a new booster and master cylnder on my 1999 f150 with the 4.6 and 4x4 and got some brakes back on my truck and the e brake light went off but the abs light is still on when i bled the brakes got the air out of the back but not getting air out of the front dose that mean the air is stuck in the proportioning valve and if so how do i bled the proportioning valve thanks for your time
Old Jul 15, 2010 | 09:56 PM
Bluegrass 7's Avatar
Bluegrass 7
There is no bleeding a proportioning valve. It is only in the rear supply line.
It's purpose is to lower the pressure to the rear brakes because they have less grip on the road surface during braking due to the weight transfer to the front, lifting weight off the rear..
If the rear were allowed to have full pressure they would lock up and become an additional danger to stopping.
ABS is a seperate function that detects speed differences between the front wheels and the rear axle speed before applying a modulating pressure to the front wheels.
Old Jul 16, 2010 | 02:01 PM
muddiger99's Avatar
muddiger99
ok then how do i fix this problem or what is the prblem
Old Jul 16, 2010 | 02:11 PM
Bluegrass 7
Did you do the master cylinder bleed procedure first before installing?
Old Jul 16, 2010 | 03:26 PM
muddiger99's Avatar
muddiger99
yeah when i went to bled the cals on the front dint get no air and used to big bottles of brake fluid
Old Jul 16, 2010 | 11:36 PM
muddiger99's Avatar
muddiger99
i bled the brake and the abs light still on and the front cals locked up so ibled it again and they dont lock up but still fell spongy and the abs light is still on but the ebrake light is off now ??????????????????????????
Old Jul 17, 2010 | 04:04 PM
muddiger99's Avatar
muddiger99
if i start from the cals and work back untill it donst unlock the front wheels then thats were my problem well be at right
COMTNMAN
Mar 5, 2014 10:58 AM
dsrtjeeper
28
Jan 22, 2014 12:14 PM
StudentOfEarth
Jun 14, 2010 03:20 PM
6LPSD
Apr 29, 2010 09:55 PM
hoperox74
Bronco II
Jan 28, 2009 05:36 PM
