Thanks, I didn't see the button. Still looks pretty nice. Might be another option if my shifter gets really bad and want to go that route. I have replaced the shifter column piece that the shifter handle mounts to twice since 92. Getting good at it now though.
Where did you find a floor shifter for you truck. I am looking but have not found anything.
Originally Posted by Kirbys73F100
Does anyone have any suggestions for a budget minded floor shifter and/or pictures of one installed in a truck? I want it to be tall enough to be useful. I don't like the B&M ratchet shifter on a pedestal look. Thanks for any help!
Here are images of my Lokar shifter on top of a C-6. I took pictures with the shifter in 1st and in Park to show that there is enough clearance. The Lokar uses a cable system. Pretty easy to install.
When I was building my 68 F100, the Lokar was going to be my shifter of choice. Unfortunately, it was sold before it was completed. It helped pay for my 74 F100 4x4 build. I installed a NP435 in the 74, so no Lokar is needed.
I say, save for a couple months if needed and get the Lokar. From the research I have done it is the cleanest "manual" look-a-like shifter for an "auto".
Either way, be sure and keep us posted..... and we like pics.
Reason: Spelling
I think any of these shifters would work with a 2wd or 4wd. On a 4wd, the transfer case shifter should be to the left side of the transmission hump and the trans shifter should sit closer to center.
No. 2wd. This is better pics of my install which I posted above. Electric fan switch + LED Indicator and wideband O2 gauge will be going there as well. Why would a 4wd be different? Mount it to the side of the lever.
