90 F250 Idle Lobes/Stalls
I have a 90 F250 w/5.0. I just changed the fuel tank float as it was full of gas and not reading on the dash. I also replaced the filler hose that was faulty. I was bleeding the brakes and had some air in the front right tire. I did not touch anything besides the battery in the engine compartment. Now the truck stalls or the idle drops to about 500 when I push the clutch to stop. The check engine light came on and then off again after driving. No problems when running in gear. I know the EGR could stick or the IAC could not respond correctly but I never touched any of that and it ran fine. Please help. Thanks.
Ford Fuel Injection How To Run a Self-Test here is a link on how to check for trouble codes using the check engine light. Yours should be 2 digit codes.
Getting the codes may help in pinpointing the problem.
Still not working right
The codes did read 33 or EGR not reading opening. The issue is that it happened after working on the gas tank. I worked fine before and I think that it is too much of a coincidence that it stalls now. I started it yesterday before cleaning the EGR and it started right up and then stalled. Idle around 500-600.
Changed EGR
I broke down and changed the EGR and it does idle much better. However, when I started it after the change it stalled right off the bat then restarted it and ran better. I have not driven it yet and will try today. I want to also reset the codes and recheck after my drive. I have not checked the fuel pressure and don't know how.
sulldog66
08-26-2008 03:10 AM
