question
Old Jul 14, 2010 | 11:09 PM
Rick Wallace's Avatar
Rick Wallace
question
On the dash there is the wait to start light ,I have a manual GP sys,love it,the old lights are still in there with a wad of wires hooked to the back.Do those wires only go to the old GP sys and can they be eliminated?I need that spot for something else.
Old Jul 14, 2010 | 11:13 PM
poocher pup's Avatar
poocher pup
yes you could remove them if you need to.
Old Jul 14, 2010 | 11:17 PM
Rick Wallace
OK, I didnt want to stuff them up in there if they wernt needed
Old Jul 16, 2010 | 09:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle
On the 86 that diesel warning panel has three lights.
Wait to Start
Engine overheat
Water in fuel
Given the location, in many instances, especially if you are fairly tall, you will not see the lights come on while driving unless you specifically look down there.
Poor place for a warning panel in my opinion.
Mine has been unhooked for several years.
Old Jul 16, 2010 | 09:30 PM
Rick Wallace
Thanks dave, I want to use that space to put two power plugs,I dont have one since I took the ashtray assembly out and put my CB in that spot.,BTW Dave the instrument panel pic in your album,did you make that or is it availible? I really like it
Old Jul 17, 2010 | 11:50 AM
Rick Wallace
And is it possible to add a tach where there wasnt one before??
Old Jul 17, 2010 | 03:01 PM
Rick Wallace
Dont every one answer at once.............lol
Old Jul 17, 2010 | 03:20 PM
kenpobuck's Avatar
kenpobuck
I think Dave built his panel. As for the tach I don't see why you couldn't put one in. I think they put a clock Or something in the place it would be. Find the tach outof a suitable year and a tach sensor and wire it in. I know that the wiring is on here some where. I used it when I hooked mine up going from gasser to diesel instrument panel.
Old Jul 17, 2010 | 03:24 PM
Rick Wallace
Just making long range plans.....I really like Daves that looks good,I need to go to numbers anyway
Old Jul 17, 2010 | 07:43 PM
Dave Sponaugle
Actually that dash was done by a member here several years ago.
And I have no idea who it was.
If you get the insturment panel out of a diesel with a tach, you should have the wiring in the stock harness.
So you just plug the insturment cluster in on one end and add a tach sensor to the engine.
If the cluster does not have a tach, the printed circuit on the back will not have the correct circuits for the tach.
When I added mine, I just bought a complete cluster and changed it out.
Old Jul 17, 2010 | 08:02 PM
Rick Wallace
Thanks Dave
Old Jul 17, 2010 | 08:11 PM
kenpobuck's Avatar
kenpobuck
I was just on the local upull sight and they have instrument clusters for $25! i might have to run over there and snag one for a 83-86 diesel. I will have to wire the tach in again myself tho lol.
Old Jul 17, 2010 | 08:20 PM
Rick Wallace
That would work,How about an aftermarket tach? or one out of a big rig?
Old Jul 17, 2010 | 08:23 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Yes, You need the Tach & Circuit film, Tach sensor.
Or a complete cluster and Tack sensor.
Some motors do not have the Tach sensor location in the IP drive cover though, so you might need one of them as well.
[edit] ... Geez $25 bux, I just paid $75 plus shipping from WA. Sucks have no yards around. [/edit]
-Enjoy
fh : )_~
Old Jul 17, 2010 | 08:25 PM
Rick Wallace
Ive got the hole there,its just a plug in there,,another long range project,just wondered if it could be done in case I run across one.....
