Not getting enough spark
Old Jul 14, 2010 | 11:02 PM
Rothschild's Avatar
Rothschild
After going through the motions with my truck, I've found a new problem.
1988 F150 5.8 ltr.
Drove my truck to the gas station. While filling up, the truck stalled out. I turned the key and it kept kicking but would not turn over. I managed to get the truck started and then drove it home as it wanted to stall out on the way.
After getting the truck home, it stalled out again & would not turn over. Thought it wasn't getting fuel, but found it wasn't getting the spark when I pulled out a plug connected to the a plug wire.
I seem to be having an on going problem. My truck runs for a while, now it stalls out and doesn't want to start until things cool off?
Something is getting hot & making it stall until it cools down. What could it be?
Old Jul 15, 2010 | 06:41 AM
DBGrif91's Avatar
DBGrif91
First thought would be ignition coil. These are classic symptoms of a bad coil.
How long since you last changed the plugs/wires/cap/rotor?
Old Jul 15, 2010 | 07:08 AM
Conanski's Avatar
Conanski
Pull the codes first, it sounds like you have a bad TFI module and if so there will be a code for it.
Old Jul 15, 2010 | 07:32 AM
DBGrif91's Avatar
DBGrif91
...there's always that...
Old Jul 15, 2010 | 12:55 PM
Rothschild's Avatar
Rothschild
I have an OBD 2 & 1....this is what I got....
DTC:23
1. Throttle position (TP) signal sensor out of range.
2. Fuel injector pump level sensor input is out of self test range ( Diesel )
My truck isn't a diesel.
Old Jul 15, 2010 | 03:21 PM
danr1's Avatar
danr1
X2 to Conanski suggestion.
DTC:23
Where'd you find those definitions?
<table table="" style="font-size: 100%;" border="1" cellpadding="2" cellspacing="0"><tbody><tr><td>23</td> <td><center>X</center></td> <td> </td> <td><center>X</center></td> <td>Closed throttle TPS voltage higher or lower than expected.</td></tr></tbody></table>
Try it again and post the codes you get if any, ('88 model will post 2 digit codes).
chandrabites
Jun 20, 2014 04:36 PM
tdbarlow1
Jun 5, 2014 11:22 PM
drpepperinacan
Jan 22, 2012 10:14 PM
Rothschild
Oct 20, 2010 07:38 AM
84RedF150
Jan 9, 2006 11:40 PM
