Did you know this???
Old Feb 10, 2003 | 05:29 PM
Ratsmoker's Avatar
Ratsmoker
In the heyday of sailing ships, all war ships and many freighters
carried iron cannons.
Those cannon fired round iron cannon *****.
It was necessary to keep a good supply near the cannon.
But how to prevent them from rolling about the deck? The best storage
method devised was to stack them as a square based pyramid, with one ball on
top, resting on four, resting on nine, which rested on sixteen. Thus, a supply of
30 cannon ***** could be stacked in a small area right next to the cannon.
There was only one problem -- how to prevent the bottom layer from
sliding/rolling from under the others. The solution was a metal plate with 16
round indentations, called a Monkey. But if this plate was made of iron, the
iron ***** would quickly rust to it. The solution to the rusting problem was
to make Brass Monkeys.
Few landlubbers realize that brass contracts much more and much faster
than iron when chilled. Consequently, when the temperature dropped too far,
the brass indentations would shrink so much that the iron cannon ***** would
come right off the monkey. Thus, it was quite literally, Cold enough to freeze
the ***** off a brass monkey!
And all this time, you thought that was an improper expression, didn't you?
Old Feb 10, 2003 | 05:33 PM
Mil1ion's Avatar
Mil1ion
I posted this last fall, and it took all of 30 minutes for people to strike me down.
It is known as an Urban Legend or Myth
Check it out.
http://www.urbanlegends.com/
Old Feb 10, 2003 | 05:38 PM
AggiePSD's Avatar
AggiePSD
Hey its still a good story though
Old Feb 10, 2003 | 05:51 PM
Ratsmoker's Avatar
Ratsmoker
Gosh, ya killed it Dennis. I got that from a friend at work. I will let him know it is a myth. Thanks.
Old Feb 10, 2003 | 05:52 PM
Ford_Six's Avatar
Ford_Six
http://www.tafkac.org/language/etymo...ss_monkey.html
I did a search, and it seems that this confirms the original story.
jskufan
May 16, 2004 07:07 AM
BuiltToughF250
26
Dec 27, 2003 12:41 PM
ctfuzzy
Oct 28, 2003 09:59 PM
Mil1ion
27
Nov 22, 2002 06:51 PM
