Transfer Case Problem
Old Jul 14, 2010 | 01:19 PM
Blue_Betty's Avatar
Blue_Betty
I just bought an 86 f150. It is 4wd and has the 300 cid motor with a 4 spd trans. It has the 208 transfer case but it wont work in hi. (not in 2-hi or 4-hi). when it is in hi and i let off the clutch, i hear a terrible noise coming from the transfer case area and the truck doesn't go anywhere. if it is in 4-low, it seems to operate fine with no noises or slipping. the guy i bought it from said that it just needed a chain put in it, but its my understanding that the chain only operates the front output. If that is the case, then it doesn't explain why it doesn't work in 2wd mode. has anybody had a similar problem to this or does any body have any ideas what could be causing it. does it just need a simple rebuild or should i look for a used one to swap it out with.
Old Jul 14, 2010 | 02:10 PM
Franklin2's Avatar
Franklin2
Make sure the shifter is working ok. Other than that, there must be something wrong inside the case.
Whether you tear it apart or get a used one would depend on how much time the truck can be down, and if you feel up to getting into the insides of the case.
Old Jul 14, 2010 | 02:39 PM
Blue_Betty's Avatar
Blue_Betty
it seems like the shifter is working ok. i can move it forward and back and it feels like it is working properly. Is there another way to check it to be sure though?
Old Jul 14, 2010 | 03:46 PM
Eddiec1564's Avatar
Eddiec1564
The NP208 xfercase has some plastic shift ears that wear out causing hard shifting.
Old Jul 30, 2010 | 01:28 AM
onseytote's Avatar
onseytote
Originally Posted by Blue_Betty
rebuilt transfer case seems like the shifter is working ok. i can move it forward and back and it feels like it is working properly. Is there another way to check it to be sure though?
I suspected a shifter prob too but if you're saying it's ok I think you should go for a swap.
npearman
31
Feb 16, 2016 04:01 PM
nowafordman
Aug 12, 2010 04:16 PM
acm05fsu
1997 - 2003 F150
19
May 1, 2010 09:56 PM
rascal1
Oct 4, 2007 08:56 PM
sam23
Aug 3, 2004 12:08 AM
