engine stands
Old Jul 14, 2010 | 01:21 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
I pulled the clip!
And am very glad I did for many reasons, most importantly was the easy access to everything.
-Enjoy
fh : )_~
Old Jul 14, 2010 | 01:25 PM
Rick Wallace's Avatar
Rick Wallace
Radiator and hood is already off,will the piece going across that hols the hood latch and all that come out in one piece? I know its just a latch but Im sure ill screw that up!
Old Jul 14, 2010 | 01:36 PM
kenpobuck's Avatar
kenpobuck
I think it is a couple of bolts that hold the latch to the support. The rest is held by bolts at the fenders and 2 at the frame horns. I would pull the batteries to reduce the wieght that will be on the fenders Whe nther support is out.
Old Jul 14, 2010 | 01:40 PM
Festus Hagen
Methanoholic
That would be the core support ... It detaches at the fenders and support mounts, it's pretty easy to remove UNLESS the truck is rusty!
-Enjoy
fh : )_~
Old Jul 14, 2010 | 01:43 PM
Rick Wallace
Im lucky there NO RUST!!
Old Jul 14, 2010 | 01:45 PM
kenpobuck's Avatar
kenpobuck
Gotta love the far south.
Old Jul 14, 2010 | 01:46 PM
starmilt's Avatar
starmilt
Rick before I used the harbor freight cherry picker I would rent a good one especially if you are not planning on using it much. Personally I would stay away from the engine stand unless it is one with the cross piece in front and has 4 castors on it. The ones with 3 castors are just too light for these motors.
Old Jul 14, 2010 | 01:51 PM
Rick Wallace
I only plan to use it twice! one pull one put in!! Thanks thats the answer I needed!
Old Jul 14, 2010 | 01:58 PM
kenpobuck's Avatar
kenpobuck
That is a good idea star. My stand has the 4 castors and the front cross but the 6.9 was still to much for it.
Old Jul 14, 2010 | 02:20 PM
Festus Hagen
Methanoholic
Lucky dog!
-Enjoy
fh : )_~
Old Jul 15, 2010 | 09:01 PM
kenpobuck's Avatar
kenpobuck
Hey her we go. This should work as it was your post lol. What all was your truck doing before you parked it?
Old Jul 15, 2010 | 09:13 PM
Rick Wallace
Yea, you know I had the runaway problem first,the cause of that was a leak on the IP where the throttle shaft goes thru,I took it out and put new O-rings in and put the top back on wrong,,,,and there she went!!!,I then took the pump off,,the wrong way of course,got it out of time,finally got it running,it was running rough and chuffing,so I put new injectors and elec fuel pump and new water seperator,got it running again,it was very very rough,chuffing louder than that vidio,so I assumed it had a broke rod or somthing,,,,now Im not so sure,
Old Jul 15, 2010 | 09:17 PM
  #28
kenpobuck's Avatar
kenpobuck
Ah I see. Well with any luck it was just a bad valve. I know it is a bit caveman like, but I have always checked the valves (with the head off the engine) by pouring water in the passages and watching to see if it seeped out.
Old Jul 15, 2010 | 09:24 PM
  #29
Rick Wallace
Ill try that tomorow,and of course I found FTE after I took the pump off! After I ran out of money I got disgusted with it and parked it,saved up some $ then the A/C in the house went out! You know how sheet is,it happens!!! But ill get it ..
Old Jul 15, 2010 | 09:32 PM
  #30
kenpobuck's Avatar
kenpobuck
Oh ya I know. I just so happened that we had bought this house just before my started chuffing. I used part of the rebate for the fix lol. Of course right after that the tranny went out. That killed my turbo plans.
