Steady Bearing Rubber Collapsed
Old Jul 13, 2010 | 10:53 PM
Scott598's Avatar
Scott598
I have a 1991 Ford F250 4X4 Supercab, A/T, 7.3 Diesel. The Steady Bearing gave out on me the other day. I could hear lots of screeching sounds and looked under and the rubber was all collapsed and pushed up the drive-shaft a bit. I took it into a garage (Canadian Tire) and they put a new one on. As I drove it out of the parking lot I could still hear that screeching sound once in awhile. After driving it a bit and it started vibrating, I looked under and the rubber was all collapsed again and had ridden up the drive-shaft at least an inch. The bearing still seems good though. The drive-shaft was out of the transmission a inch or two more than usual.
I would really like to know what is causing this to happen? My suspension seem tight so my axles is not moving. I did notice after taking it apart tonight that the front universal joint is worn out, but doubt that this could cause the problem.
Any suggestions/comments would be much appreciated. Thanks
Scott
Old Jul 14, 2010 | 09:59 AM
tjc transport's Avatar
tjc transport
i ain't rite
you answered your own question with your last comment.
i was going to suggest inspecting for bad universals.
Old Jul 14, 2010 | 09:39 PM
Scott598's Avatar
Scott598
Universal Joint vs. Steady Bearing
I am curious to the theory behind having a universal joint destroy a steady bearings rubber? I just can't picture it in my head!
Old Jul 15, 2010 | 06:13 AM
tjc transport
i ain't rite
if the universal is bad, it will throw the driveshaft out of balance and tear the carrier bearings isolator rubber apart.
Old Jul 15, 2010 | 06:49 AM
Scott598's Avatar
Scott598
Vibration
Ok. I will take your word for it. The new one I put in seems to be working. It never came with a clip on top of it (from bolt hole to bolt hole) though and am now wondering if NAPA sells that model that way. I will have to wait until they get some new one's in to compare.
Thanks.
wolfpacker02
Escape & Escape Hybrid
May 30, 2014 12:54 PM
ATC_250SX
Feb 24, 2013 05:37 PM
Bassun
2004 - 2008 F150
Feb 17, 2011 10:26 PM
RRHogger
1983 - 2012 Ranger & B-Series
Dec 31, 2003 09:35 AM
rssnape
Sep 9, 2003 09:49 PM
