Replaceing the clutch
Old Mar 12, 2003 | 08:13 PM
92f150I6's Avatar
92f150I6
Sorry, I haven't replied. I thought I fixed it.
Anyway, it turns out that my slave cyl is leaking fluid, and I will need to replace it soon. My truck is 2WD and I have access to a lift and tranny jack, so I am going to do it myself. I was told to go with the LUk or Borg Warner clutch. As to the slave cyl, have most aftermarket parts been ok? Or should I get motorcraft?
I do want quality pieces which will last.
Thanks for all of your help.
Old Mar 12, 2003 | 09:42 PM
ajstephan's Avatar
ajstephan
I don't know if a Motorcraft will necessarily be better, as the factory slave cylinder went out at 50K miles, although the Ford dealer replaced it and it lasted 70K miles until my clutch replacement, when I replaced it even though nothing was wrong with it. I didn't give it much thought at the time, but I've got Wagner slave cylinder in now.
If you're that concerned, just get a Motorcraft. Probably the safest bet.
Old Mar 13, 2003 | 06:49 PM
bob the viking's Avatar
bob the viking
A couple friends and I did my '91 F-250 4.9 4x4 5 speeds clutch a month ago. I got Ford everything... Clutch, pressure plate, slave cylinder (included the throw out bearing),pilot bearing, and I decided to get a new flywheel. It really wasn't too horrible to do. I had less than $500 in parts. A local transmission shop wanted between $700 and $800 to do it and I wouldn't have gotten a new flywheel.
Old Mar 30, 2003 | 06:25 PM
92f150I6's Avatar
92f150I6
After putting it off, I replaced the clutch and slave cyl today. It only took 2 hrs. went very smoothly. My flywheel was in good shape with no grooves or burn marks. I ended up using a Borgwarner clutch and raybestos slave. Here is hoping for long life. thanks for all the help.
1990-f250
Mar 14, 2015 09:38 AM
rangergirl94
Oct 13, 2011 04:52 PM
fordfinatic
Feb 7, 2009 09:04 AM
JohnT
May 13, 2006 08:25 PM
Charlie99
Feb 12, 2002 05:24 PM
