Front clip replacement
Old Jul 13, 2010 | 12:22 PM
redhawk41's Avatar
redhawk41
I am about to replace my front clip on a 79 bronco with a front clip off of a F100. How hard is it and what all do I have to take off to replace everything from the cab forward?
Old Jul 13, 2010 | 11:49 PM
radar457's Avatar
radar457
its not to hard.. hood off..unplug all wiring, lights, ing module, etc. pull radiator. the 2 front bolts on either side of the radiator are the worst. may have to use a torch on those 2. ...3 bolts on either side behind the hood hinges, one 9/16th bolt on either side on the rear under side of fenders,, ..... 2, 1/2in upper rear fender bolts,(you will find them by opening the door and look behind the top door hinge). .then heavy rubber strips that hold inner fender to the cab (look behind each wheel where the rear of the inner fender meets the frame)...it should be loose.
