Dumb question
Old Jul 12, 2010 | 10:00 PM
Ooftus's Avatar
Ooftus
Dumb question
Does the ballast resistor have any effect on the charging system ?......I switched back over to ' points ' after one too many MSD failures.......Installed inline ballast resistor from key to + side of coil, ran wire from ' I ' post on solenoid to + side of coil.......Now alt. is barely putting out 12 volts.......Did I goof up somewhere ?
Old Jul 12, 2010 | 10:57 PM
oldbrokecowboy's Avatar
oldbrokecowboy
Check your grounds.
