octane question
Old Jul 13, 2010 | 03:39 PM
B Big's Avatar
B Big
I had a '70 VW that I really built up the motor. I was running stroked & bored, 3/4 cam, & dual weber carbs etc. I also made the compression low (spacers under the jugs) so I could run pump gas. That car didn't like the AV gas at all, it would run like sh** no matter how much you cut the mix. Running pump gas that car surprised some folks!
Old Jul 13, 2010 | 04:51 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by ckal704
Any body that tells you they saw a performance increase of any measurable significance in a 9.5:1 compression ratio engine running 95 or higher octane fuel is full of it.
These are facts. Google octane if you want more info.
There is no performance increase if nothing has been done in the tuning to take better advantage of the slower combustion rate.
You're right though, there will be no increase in performance.....and most likely a slight decrease in performance due to very high octane fuel.
Old Jul 13, 2010 | 04:59 PM
MustangMatt96GT's Avatar
MustangMatt96GT
I plan on it eventually. Problem is getting bigger metering blocks for my Carb on my budget haha but my fuel system will support it, just a matter of convertoring my Carb to beable supply the extra fuel needed.
Originally Posted by MADVAN
Go with E85 for the drag car.
Its the best bang for the buck.
Your fuel and tune will have to be increased approc 30%+
Bill
Old Jul 13, 2010 | 07:47 PM
MADVAN's Avatar
MADVAN
The leaded fuel will take out your O2 sensors first.
Then limp mode will finish off the cat.
Nat *** street cars are running in the low 13's in compression on the E85 fuel.
B
Old Jul 13, 2010 | 07:56 PM
MustangMatt96GT
B
Yeah I could run around 38 degrees timing in street trim because of the octane rating of E85. Instead when I wanna drive it any distance I put 91 in it and drop timing to 20 degrees.
Old Jul 13, 2010 | 08:30 PM
MADVAN's Avatar
MADVAN
S-Plug change and have seen 40 to 42* before the power falls off.
Most run here. Nova is one of ours.
F.A.S.T. - Factory Appearing Stock Tire - Home -
Old Jul 13, 2010 | 08:36 PM
MustangMatt96GT
Unfamilar with S plugs. I know my motor likes right around 34-36 on 110 sunoco purple depending on the DA of the day.
pdqford
Mar 4, 2008 07:13 PM
bookum1
Modular V10 (6.8l)
17
Nov 6, 2007 06:42 PM
tjay460
General Automotive Discussion
Mar 29, 2006 09:17 AM
Geoboy
Modular V10 (6.8l)
20
Jan 21, 2004 09:32 PM
ford_prof
Computer Chips & Tuners
Sep 15, 2003 07:45 AM
