I have a slight squeaking coming from the driversside front tire area. When i press the brakes it goes away. Could this just be my front brakes need to be replaced?
The caliper is most likely to blame. Had both rear calipers replaced because of hang up of the slide pins (notorious for the SD's) front driver started squealing, same issue. Your pads maybe fine.
Yeah surely the caliper must be the problem there is no problem with the brake pads and also check for the bearing of the wheels from where the sound is coming.
i've got the same thing on my 2010... took it to the dealer and they said it was the metallic brake pads. not to sure what to think of that, but i've got the piece of paper saying they said everything was ok.
