Intermittent boost loss on grade
Old Jul 12, 2010 | 07:20 PM
npccpartsman's Avatar
npccpartsman
Originally Posted by cheezit
tim the cold side goes from the cac to the intake.
the hot side is cac to turbo.
LOL--maybe I should have said the fresh air side of the turbo, which is aluminum vs the exhaust side which is cast iron. I'm not clear on where he is seeing this brown stain on the turbo.
That's great Tim, thanks. I'll PM you my email addy.
Old Jul 12, 2010 | 07:40 PM
cheezit's Avatar
cheezit
ok if the oil got that hot wich would have to be higher then 350*f. very easy theroy to test.... remove the oil filter and see if the stand pipe is still there. it will melt at 350*.
if oyu have a broken y-pipe you have an exhaust leak that is ever present look for soot on the fire wall.
Old Jul 12, 2010 | 08:02 PM
bpounds's Avatar
bpounds
I hesitate to even offer an opinion because you guys know so much more about this than I. But defueling due to overheating sure seems like it matches his symptoms. That overheating could be the oil or coolant. I'm thinking oil due to a clogged cooler, and the boiling sound is in the EGR cooler.
It's okay to laugh at my stupid ideas, I won't be offended.
Old Jul 12, 2010 | 08:06 PM
cheezit's Avatar
cheezit
05 with the latist flash would but imo weres the wrench light. assuming the op has a message center.
Old Jul 12, 2010 | 08:14 PM
olfordsnstone's Avatar
olfordsnstone
OK, After I fought with trying to post the picture, I then saw this post. OK, it's on the hot side of the turbo. The CAC tube to the radiator, not the side that goes to the intake.
If you guys can pm me your e-mail address I will send you a pic of the brown stain. I don't think the FTE e-mail feature allows pics to be sent and I aint no computer geek, FOR SURE.
Old Jul 12, 2010 | 08:17 PM
cheezit's Avatar
cheezit
tp post a pic make a photobucket account, upload the picture there and copy the text that says image. then past that text to your reply here.
Old Jul 12, 2010 | 08:26 PM
olfordsnstone
Actually I have just sent a pic to NPCCPARTSMAN . NPCC, please post the pic, if you can. The wife is on myass... LOL. Overdue honeydo list. She's kinda pissed. I'll be back and forth to the computer to check on progress.
Sorry. Gotta keep the honey flowing or this'll be one tough house to live in... Be right back...
ON EDIT: Here ya go. I hope this works...
<a href="http://s971.photobucket.com/albums/ae200/TimScherer/?action=view&current=100_4658.jpg" target="_blank"><img src="http://i971.photobucket.com/albums/ae200/TimScherer/100_4658.jpg" border="0" alt="turbo stain"></a>
Old Jul 12, 2010 | 08:31 PM
cheezit's Avatar
cheezit
So when the dogs at the back door barking and the wife is at the front door yelling wich one do you let in first? and why?
LMAO
Old Jul 12, 2010 | 08:40 PM
rickatic's Avatar
rickatic
Neither, in my case I just hide
Old Jul 12, 2010 | 08:45 PM
rickatic's Avatar
rickatic
Buff...
I have not seen the new products. The Insight I bought last year worked great. I did not plan to use it on the new truck so it now resides in John Diems truck. It works great there too.
Old Jul 12, 2010 | 09:05 PM
olfordsnstone
OK, OK, ha ha, very funny guys. I went in and set her straight, for the record... so the dog got a pet on the head and the DW got a pet on the head LOL. Don't tell her I said that...
BTW, I posted the pic of the turbo with an edit in my last post. Please see that one above. Thanks for the destructions on how to post pics Cheezit.
Old Jul 12, 2010 | 10:10 PM
npccpartsman
The stain on the turbo is normal. It may be a little bit of CCV oil seeping from the end of the hose--bleed threw (through?). As for the whistle--what all, if anything, did ford do or replace or can you point towards an old thread? Did they ever smoke test the system? Ever consider an intake gasket or EGR cooler to intake gasket? I can only think of so many things that would whistle--y-pipe system, intake gaskets , head gaskets (degas bottle cap whistle), belt and associated parts (constant or rpm related). Also, is the whistle a constant pitch or does it vary?
Old Jul 12, 2010 | 10:26 PM
  #28
olfordsnstone
Whistle is constant pitch. Seems to come on when rpms and fan clutch are in sync. I am starting with Y pipe (part of egr delete). I will also go through and check all of the exhaust manifold bolts that I can reach. If this does not stop the annoying whistle, I am probably going to eventually try changing the belt and idler pully. I have also been told that a clutch fan from a snow plow package is a good improvement on the 6.0, especially for towing, but that will probably have to wait until I have more funds. I would think that if the whistle is heat related, a more efficient clutch fan might help keep it cool...
The most concerning issue right now is the boost problem. We'll see if the egr delete fixes that one. If not, I will be combing these pages to see if there was something I missed that someone may have suggested and I missed. Knowing that the brown staining is normal is a relief to me as I really don't want to consider a new turbo at this point. I'm just about out of money once the egr delete is accomplished.
Thanks for all the help. If you all think of anything else, please send me your thoughts.
Thanks, T
Old Jul 12, 2010 | 10:33 PM
  #29
olfordsnstone
Ford has not done anything for the whistle. I could not replicate it any of the times I brought the truck in. They looked at it but could not do much without hearing it first hand.
Here is the thread I started a long time ago on the whistle. It appears that I'm not the only one...
https://www.ford-trucks.com/forums/6...eavy-load.html
Old Jul 13, 2010 | 08:34 AM
  #30
LostMedic's Avatar
LostMedic
Originally Posted by olfordsnstone
1) What's going on with my lowering boost and loss of power? I'm getting ready to do a long road trip with my trailer in a couple of weeks and need to get this sucker fixed soon. Does this sound like a turbo problem? or could this be egr and coolers related???
Based on my experience with E350 ambulances here in Switzerland, this is a common point of concern from medics, which only occurs during hot days (about 100°F these days and going uphills, not uncommon around here). Engine heats and fan takes over, resulting in a very high whine and big loss of power. I am not sure if this answers this specific question but your description goes completely along those of the medics. We've never had technical issues resulting from this
