How often do you change the tranny fluid? What about the diff, brake fluid, ATF in the power steering system? When is the last time you changed the serpentine belt or flushed the coolant system? What about checking the SCA levels in the coolant? Hopefully you've changed the shocks by now, do they need replacing again?
