engine loses power
Old Jul 11, 2010 | 12:15 PM
pete315's Avatar
pete315
engine loses power
I've noticed that my 97 4.0 Explorer feels like it's running out of gas sometimes after cruising at highway speeds then slowing down. I have a new fuel filter. Fuel pressure was checked and is good. Car just threw a check engine light- code for O2 sensor. Would a bad O2 sensor make a car run real lean causing it to feel like it was running out of gas?
Old Jul 11, 2010 | 05:14 PM
aquanaut20's Avatar
aquanaut20
in short, YES
But you need to complete proper diagnosis to find correct cause.. no guessing, costs $$$$
Old Jul 11, 2010 | 08:56 PM
pete315's Avatar
pete315
I code code P0153- bank 2 sensor #1. I'll guess I'll change that O2 sensor. just have to do a search and find out which O2 sensor it is.
Old Jul 11, 2010 | 09:08 PM
aquanaut20's Avatar
aquanaut20
bank 2 = driver side,
sensor 1 = first one downstream of engine...
Old Jul 11, 2010 | 10:08 PM
pete315's Avatar
pete315
I hope this solves my lack of power problem. car had full tune up not too long ago. I don't think I have a vacuum leak because I have a smooth idle. plus the lack of power is intermittent. this P0153 code is the only code I got.
Old Jul 11, 2010 | 11:54 PM
aquanaut20's Avatar
aquanaut20
I would clean the MAF first, cheap, easy and calculates the volume of air entering the engine... ensure no illegal air between MAF and throttle body...
Recall I advised, test first before spending $$$....
Old Jul 12, 2010 | 10:03 AM
powersmoked's Avatar
powersmoked
that code alone indicates that there is a 95% chance the sensor is bad......if you have more than 100k on the truck it should be replaced anyways as maintenance
Old Jul 12, 2010 | 04:33 PM
pete315's Avatar
pete315
I just put a new MAF sensor about 2 weeks ago. I got that code. judging by the way these O2 sensors look, I bet they are original. truck has 127,000 on it. That O2 is super tight. my 7/8 O2 socket felt like it was about to strip the sensor. I'm going to bring tuck to friends shop and heat up sensor to loosen. I hope O2 sensor is not seized in there. I was able to turn sensor about 1/4 turn only. After that, it felt real tight.
Old Jul 15, 2010 | 12:00 PM
V8Ranger302's Avatar
V8Ranger302
I just put a new MAF sensor about 2 weeks ago. I got that code. judging by the way these O2 sensors look, I bet they are original. truck has 127,000 on it. That O2 is super tight. my 7/8 O2 socket felt like it was about to strip the sensor. I'm going to bring tuck to friends shop and heat up sensor to loosen. I hope O2 sensor is not seized in their. I was able to turn sensor about 1/4 turn only. After that, it felt real tight.
In my experience with o2 sensors starting to come out then stop is, they usually come out striped, but the threads in the bung on the pipe are usually ok. The treads in the hole are harder than the ones on the sensor. Thats what I have alway run into anyway.
Old Jul 15, 2010 | 03:11 PM
pete315's Avatar
pete315
we used a torch and made them cherry red, then was able to loosen. so far, car seems to be running good.
stinger381
1997 - 2003 F150
Jun 10, 2018 12:58 AM
paxmick
1983 - 2012 Ranger & B-Series
Dec 12, 2016 10:36 AM
96halfton
Nov 6, 2016 04:31 PM
Shadow351
3.8 & 4.2L V6
Sep 2, 2011 11:22 PM
ricket
Nov 14, 2003 01:34 PM
