Question - Ignition Switch Wiring
Good afternoon!
The PO of my '65 F250 2wd had put on a generic ignition switch, and I decided to restore the switch to something more appropriate that I got through Dennis Carpenter. I've found that the PO did some "interesting" things to the electrical wiring, and I'm trying to correct some of those issues. I've got a wiring diagram from another Ford truck site that I have mostly figured out, but there's one symbol that eludes me. Can someone tell me or show me what the < symbol that I have circled in red mean? Wire 37 comes from the battery connection on the starter solenoid and splits with wires going to the BAT terminal on the ignition switch, the headlight switch, and the fuse box. The other yellow wire appears just to dead-end. Help! Thanks.
There are definitely what appear to be "unused" connectors in the under dash wiring harness. Some of them are likely test points that they used to check with a test light or other meter. The one you circled - 21 - would check the all important "power to the ignition switch" coming from the (B)attery side of the Relay. Just above it you should find number 137 which would check the "power to the headlight switch, stop lamp switch and turn signal flasher".
scottlathrop
11-24-2013 07:54 AM
Dr_Barker
01-26-2013 09:41 AM
65custom_cab
15
07-22-2010 06:01 PM
petty437
01-04-2007 05:36 PM
