Identifying a tow package
Old Jul 10, 2010 | 03:39 PM
Mark8246's Avatar
Mark8246
I am a soon to be 1st time truck owner. I am currently looking at an '07 F150 with 4.6L V8. I plan on towing with this truck (4000-5000lbs).
Can someone let me know how to determine if this truck is equipped with a "tow package"? It is equipped with a hitch and elec. hookup. Should/Does it have a transmission cooler? The current owner doesn't know. Anything else I should look for?
It has only 16K miles and looks like it has never towed or plowed.
Thanks
Mark
Old Jul 10, 2010 | 03:49 PM
fire240's Avatar
fire240
if it has the tow package there should be a tranny cooler in front of the condenser and radiator. you should also have the hitch as well as a 7 way round connection and a 4 way flat connection.
Old Jul 10, 2010 | 04:01 PM
tolliewolly's Avatar
tolliewolly
is the transmission cooler small or big?
I noticed a small black cooler under the radiator. Is that it?
tolliewolly
well its under to in front of the radiator
Old Jul 10, 2010 | 04:04 PM
fire240's Avatar
fire240
that sounds like it to me. it would be wider than it is tall.
Old Jul 10, 2010 | 04:16 PM
Mark8246's Avatar
Mark8246
Thanks Shaun. If I remember correctly it has all the things you mentioned. Do you know if there a transmission temp gauge that might be in the dash?
Old Jul 10, 2010 | 04:31 PM
fire240's Avatar
fire240
im not sure if th e04 to 08s had them mark. I know the 09s and up have a tranny temp gauge.
Old Jul 10, 2010 | 04:56 PM
bigunit54's Avatar
bigunit54
I have a factory tow pack, and no there is no transmission temp gauge
Old Jul 10, 2010 | 04:59 PM
fire240's Avatar
fire240
Thanks for letting me know. I wasnt sure.
Old Jul 10, 2010 | 11:45 PM
Lady Fitzgerald's Avatar
Lady Fitzgerald
Most, if not all, of the 04-07s had a transmission cooler mounted in front and slightly lower than the radiator. Most tow packages had larger ones (there were a few that didn't).
The easiest indication is there will be a combination 4 pin and 7 pin socket alongside the receiver (aka hitch).
Since somebody could have installed the 4/7 pin socket to make the truck appear to have a towing package, an even better way is to download the factory window sticker from http://services.forddirect.fordvehicles.com/inventory/WindowSticker.pdf?vin=[your VIN here] (do not leave the [] in when typing in your VIN). It will show if it has the tow package or not.
Old Jul 11, 2010 | 09:13 AM
60DRB's Avatar
60DRB
...I tried that but got a "did not match" message?
Old Jul 11, 2010 | 10:14 AM
tolliewolly
Mine did not have a hitch on it all. I had to add one and get the wiring done too.
Old Jul 11, 2010 | 11:59 AM
Lady Fitzgerald
I'm thinkin' it will work only with '07 and up. I just tried it again with my '08 and it worked.
Old Jul 11, 2010 | 03:33 PM
tolliewolly
cool...I got my sticker. It said I had a 6800 towing package. Its funny it didnt have a hitch though. I added one anyways! Thats a cool website!
Old Jul 11, 2010 | 05:17 PM
Oldguy4's Avatar
Oldguy4
I put in a Scanguage II unit. One of the many X guages that you can program is transmission temp.
dooger54
All Things Towing
Apr 9, 2020 11:24 AM
sailorgirl
Escape & Escape Hybrid
15
May 17, 2016 12:42 PM
johngeorge
Nov 13, 2011 10:20 AM
VictoryVegasJackpot
2009 - 2014 F150
Apr 6, 2010 08:47 AM
adsacu
Jun 2, 2005 06:04 AM
