Sponsored by: Auxito
stolen truck now wont start
Old Jul 10, 2010 | 01:33 PM
scotts630's Avatar
scotts630
my truck was stolen and recovered,missing some parts of course. problem is once I replaced battery,starter,ignition switch,truck doesn't start. when I turn the key I just get a click. even with the starter totally removed I turn the key and get one click . is this the sign of a bad ground somewhere. this is how I feel = any help is greatly appreciated.
it's a 97 F150 4.2, 5 speed
Old Jul 10, 2010 | 10:22 PM
Hybris's Avatar
Hybris
I would think that it might be security computer related issue not sure if that means taking the truck to the dealer and having them program something to accept the new parts or what but that would be my first guess.
BTW welcome to FTE sorry it's not under better conditions.
Old Jul 10, 2010 | 11:00 PM
Bluegrass 7's Avatar
Bluegrass 7
Post
The PATS system usually does not prevent the motor from cranking over.
If you just hear a click, it's the start relay pulling up but no power passing to the starter.
After the cranking issue is resolved and if the motor fails to start, then you may have a PATS issue as second problem.
Carefully check the wireing to the starter.
The ignition switch closes power thru to the start relay that closes heavey contacts to the starter from the battery..
This is the trouble point I think you are at.
Good luck.
Old Jul 11, 2010 | 06:36 AM
projectSHO89's Avatar
projectSHO89
Ford did not use PATS on the 97 and 98 F150 trucks.
Treat it as a probable bad starter and troubleshoot it.
Old Jul 14, 2010 | 01:56 PM
capriceclassicSS's Avatar
capriceclassicSS
PATS problem?
Shalom!
I was wondering if anyone may be able to shine some light on an issue I'm experiencing.
I have a 1999 Mountaineer that is a recovered stolen vehicle. It shows a P1260 code immediately after clearing the codes every time.
I have the original key for the vehicle, but it appeared as though the PATS pick-up may have been damaged as a result of the theft. I searched the bone-yards and found another 1999 with the key in the ignition and took the key and the pick-up and installed it in this Mountaineer.
I still have the same problem; Theft light flashes, P1260 code in the computer immediately after clearing codes.
Does something else have to be changed along with the pick-up ring for the key? I'm not sure were to go with this now.
Any help or info anyone may have would be GREATLY appreciated!!
God's blessings to you.
Smitty
Old Jul 14, 2010 | 03:51 PM
Ron W.'s Avatar
Ron W.
Originally Posted by capriceclassicSS
Shalom!
Smitty
As far as I know the PCM has to be programed to accept the signal sent by the chip in the key, Ford can do this and I've read that some locksmiths can also.
Old Jul 31, 2010 | 09:43 PM
scotts630's Avatar
scotts630
Originally Posted by Bluegrass 7
T
well just wanted to check back in, after checking the wiring as someone advised me I solved my problem......I had a bad ground. i feel so stupid,sometimes it's the simplest things that we over look or so sure we did it right...thanks again
Old Aug 9, 2021 | 04:46 PM
Geovany's Avatar
Geovany
hi I just had the same thing happen to me yesterday and now my truck won't start, what ended up being your issue?
Old Aug 9, 2021 | 05:05 PM
Stonedpony's Avatar
Stonedpony
They said they had bad ground that more than likely was the battery or the ground at the starter cylinder relay or the one on the starter or wire to the starter.
Old Aug 10, 2021 | 09:55 AM
formerjeepguy's Avatar
formerjeepguy
Yes, the PATS module (in the display head) needs to be programmed to the key. You can do it yourself with the free forscan app and a cheap ELM327 adapter. Google for details.
bcg
18
Jul 27, 2015 12:23 AM
alandeon
6.7L Power Stroke Diesel
31
Nov 21, 2014 06:31 AM
corbit96
Sep 16, 2014 06:56 PM
97ExplorerVictim
Jul 5, 2014 01:42 PM
cdnmshoem2002
1983 - 2012 Ranger & B-Series
Mar 9, 2010 06:48 PM
