2002 Explorer Brake Problem
Old Jul 10, 2010 | 12:26 PM
wrd0225's Avatar
wrd0225
When I drive my daughter's Explorer the brake pedal doesn't get firm until it is almost to the floor. They stop fine, except they seem so low. To me they seem mushy as first then become firm. Is his normal? How do you raise the height of the brake pedal's stopping point?
Old Jul 10, 2010 | 01:38 PM
Steina's Avatar
Steina
CO River Rat
Not sure why you would need to ask if this is normal. Anyway, as pads wear the caliper pistons have to extend more to clamp the rotor; if the master cylinder's fluid level hasn't been checked, start there.
Steve
Old Jul 10, 2010 | 05:47 PM
aquanaut20's Avatar
aquanaut20
Steve
2002 is disk on all 4, so that would not apply as the pistons should self adjust as the pads wear (unless the calipers/slides are seized).
Definitely check the fluid level, then bleed the system, get all the air out of the system. If there is no improvement, check the master cylinder for internal leakage and/or air trapped in master.. (may need bench bleeding)...
Old Jul 10, 2010 | 05:54 PM
Steina's Avatar
Steina
CO River Rat
"2002 is disk on all 4, so that would not apply as the pistons should self adjust as the pads wear (unless the calipers/slides are seized)"
If that's correct, then why does the fluid level rise when the pistons are c-clamped back into the calipers prior to pad replacement?
Steve
Old Jul 10, 2010 | 09:08 PM
aquanaut20's Avatar
aquanaut20
Steve
Because they self adjust..... the pedal height should remain constant, as the pads wear the pistons remain at the same relative distance from the pads (move outwards), that is why the pistons require retracting when new pads are installed...
BTW, old fluid must never be forced back up to master cylinder, open bleed when retracting pistons and top up with fresh Brake fluid.....
Old Jul 10, 2010 | 09:35 PM
1081's Avatar
1081
yes, you wouldn't need to adjust the peddle. If you have an un-normally soft peddle then you have some type of problem. It is either vacume, fluid, or air. I agree that you should bleed the brake lines first.
powerstroker100
Sep 21, 2020 10:12 AM
Fords412
Jan 19, 2019 08:30 PM
pop's 4X4
1997 - 2003 F150
Nov 5, 2011 04:12 PM
cabloom300
Jun 24, 2010 03:42 PM
michaelbrainardatwor
Nov 3, 2009 07:10 PM
