what would be the symptoms of a failing hydrobooster?
I have a mushy brake pedal, I think that the master cylinder is the culprit, truck has a new PS pump and has been flushed afterwords
the wierd thing is that occasonaly my brake pedal will be nice and firm like it should and I have excellent stopping power, if I pump the pedal it will be a little more firm then sink back down, but at random times I can hit the brake pedal and it can be firm and perfect
so before I do the master I was wondering what someones opinion might be toward this along with some common symptoms of a failing hydrobooster
How many miles have you put on the truck since you replaced the PS pump? Hydroboost units can be a pain to bleed. I'd check your lines running from the pump to the HB unit as any loose connections can cause the unit to suck in air pretty quick.
Powerstroker100, do you have any noise from the brake system that you can hear in the cab when on the brakes? Ever since I replaced my power steering pump my has a rattle when I am sitting at a light with the brakes on. Not trying to hijack just wondering if my truck is going that route also.
