Am I correct that the major structural difference between the 65-72 and the 73-79 cabs is that the latter are about 4 inches longer in the rear of the cab?
If that's true can I use the steel front cab/frame mounts, the underfloor center cross brace that connects both rockers and the floor sheetmetal from toe board to seat riser from a 78 cab on my 65 project? Thanks in advance for the help.
