trac-loc sounds question
Old Jul 10, 2010 | 04:46 AM
dutchlincoln79's Avatar
dutchlincoln79
Hello,
i've rebuilt my 9" ford rearend, and put a trac-loc in it with a 3.25 gearing.
Now, i test drove the car, and the trac-loc makes all kinds of noises. (when NOT going in a straight line, so when cornering)
To describe them, i'd say they sound like disk-brakes when braking with worn-out pads: metal-to-metal, so to say.
Also, there is a bit rotational play in the right axle. You can turn the wheel a bit front to rear and rear to front, before it takes the other wheel with it.
I only tested it with town cruise speeds, no highway yet.
When cornering slowly, as sayd, i hear the noises.
When i drive backwards (to park the car) it "clunks".
It does this also when i make a "S" turn, so from left to right, and then directly from right to left, for instance on a roundabout.
Does these sounds and descriptions sound familiar, or did i do something wrong with the build?
Is it possible that these sounds are from the clutches, needing to run-in?
I used a standard gear oil.
i bought the centersection with the trac-loc as it is now, being new. (there were some styropur packaging ***** in the gears, and marking dye on the tooth, so i can safely say that it is a new one.)
i go on a long trip in about 5 days from now, so i need to know if it's allright.
Any help highly appreciated, thank you.
edit:
I poured the neat little bottle of skunk smelly friction modifier (CM-19546-A1, the green stuff...)
I don't know what little gozmo's and wizard's of Oz created the friction modifier, but after 100 feet no clunk or scatter anymore...
I made a small testdrive of a few miles at various speeds and bends: As smooth as a baby's butt...
I'm stunned..
Last edited by dutchlincoln79; Jul 10, 2010 at 06:29 AM. Reason: updated knowledge :)
Old Jul 10, 2010 | 05:12 AM
xlt4wd90's Avatar
xlt4wd90
Did you add the friction modifier in with the gear lube? You need it to prevent excessive clutch grab, which can cause the chatter that you describe.
Uncle Grumpy
18
Apr 2, 2009 03:14 PM
fattmann
Oct 10, 2006 01:42 PM
bluedevil
Feb 3, 2005 08:44 PM
Annihilator
Mar 2, 2004 06:07 PM
