Compression test results.........hmmmmm
Old Jul 9, 2010 | 08:59 PM
cdelsol83's Avatar
cdelsol83
Question Compression test results.........hmmmmm
So I finally got around to doing a compression test to my 92 f150 5.0 and results came back varied......( I dont know if I'm right in the numbering of cylinders, I started passenger side closest to the bumper as 1 and came back same side and 5 as driver side closest to bumper and back)
1. 120 psi
2. 150
3. 135
4 135 white insulation on sparkplug was cracked....salesman said it xploded from inside.
5 150
6 150
7 150
8 145
#4 was culprit of the skipping of 'beat'. I also double check the sparkplug gaps and found out all were under by .008 inches lol...
After all is said and done I think my next project is to tackle passenger side of valves .......any input is appreciated
Old Jul 9, 2010 | 09:12 PM
f-150_1993's Avatar
f-150_1993
Yes you numbered the cylinders right... Your compression is still good although #1 could be better but it's still there. Yes cracked sparkplugs cause no current to pass therefore no combustion in that cylinder. Let me guess was that sparkplug kind of black at the electrode? I recently had a case like this but the pick-up coil was the culprit.
Tell us how it goes with the valves.
Old Jul 10, 2010 | 05:41 AM
cdelsol83's Avatar
cdelsol83
yup sparkplug was black.......
now i've never attempted anything as serious as valves before.....as far as tricks or tips, is there anything i should Not do when take everything off or putting it back on? and what should i look for?
Old Jul 12, 2010 | 08:21 PM
f-150_1993's Avatar
f-150_1993
Well I have never attempted to do anything like that either... wouldn't know what to tell you. But why are you opening your engine up? Do you hear a slight knocking sound inside your engine?
Old Jul 13, 2010 | 10:51 AM
cdelsol83's Avatar
cdelsol83
yea since i've changed the sparkplug, the hesitation has gone away but i hear slight light knockin sound inside, possible stickin of valves. My oil pressure is low also so eventually i'm gonna have to change rod and main bearings along with pickup tube and oil pump...
Old Jul 13, 2010 | 11:00 AM
f-150_1993's Avatar
f-150_1993
That's good and I have the same problem as you. Mine does it while the engine is cold then as it warms up it goes away. Is this how yours acts? My oil pressure sometimes drops too. I'm thinking of replacing the oil pump and the pickup tube. Then probably gonna rebuild my engine. Stick around and tell me how it's going. I'll be following this topic.
BeauF0RD
May 2, 2017 06:53 AM
TruckerATK
Oct 4, 2016 04:31 PM
MikeS29
Jun 10, 2011 09:02 AM
slavinpavin
Mar 8, 2011 05:06 PM
Katmandu2
Aug 30, 2003 02:27 PM
