Compression low on only one side. 351W 1996
Got a 1996 F350 with the 351w 5.8. Truck starting puffing blue smoke from the exhaust but only at idle and after it had been warmed up. Does not smoke on start-up or while driving. Thinking it is the rings I did a compression test to make sure. But now I'm stumped.
The compression test was on a cold motor. Here are the results,
Passenger side
1-135
2-130
3-135
4-135
Drivers side
5-150
6-150
7-150
8-150
I have no clue why one side would be so different from the other. Any thoughts PLEASE!!!??? I didn't do a wet test yet. Just don't think all the rings are bad on only half the engine.
I have pulled codes and have a 334 code on both KOEO and KOER tests. It has to be a short because everything is new (egr, sensors, vacuum lines, etc.)
Passenger side
1-135
2-130
3-135
4-135
Drivers side
5-150
6-150
7-150
8-150
Is there a lot of build up in the runners of the intake? If its a pcv valve the #8 cyl runner will be coated with oil.Usually if the rings are bad,it will smoke all the time. I would also pull the valve covers and make sure the oil return holes are not plugged with sludge.
The truck definitely doesn't smoke all the time. I run a small trash route with this truck so I am in and out of it all the time. It only starts to smoke shortly after idling and after it's up to normal temp. I can't see any smoke when I'm driving unless it too minimal to see.
I'm wondering if fresh air within the valve covers wore out the seals. The pvc valve on that side had been super loose for at least the 15,000 miles I've had the truck for.
TruckerATK
10-04-2016 04:31 PM
c2z4s9
73
02-29-2016 07:14 AM
MikeS29
06-10-2011 09:02 AM
