Sponsored by: Real Truck
Strange start problem
Old Jul 9, 2010 | 02:38 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
01 excursion 7.3L, just recently sometimes when go to start it the lights on the dash go away, exept the theft that flashes rapidly and kind of dim, and there is a rapid ticking that is coming from the fuse panel, either relay 1 or 2, but when you step on the break the ticking stops but still no start. Keep trying it and it will finally start normal. Kind of seems like possible bad ground that intermittently needs to arc through to establish the ground. This seem correct or another possible problem? I know electrical is hard to find. Thanks for any help.
Old Jul 9, 2010 | 05:40 PM
rbaker6336's Avatar
rbaker6336
Have you checked all your battery and ground connections?
Old Jul 9, 2010 | 07:10 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Not yet. Anyone have a list or diagram where they are all found?
Old Jul 9, 2010 | 10:30 PM
bayou barataria's Avatar
bayou barataria
My wife's expo did that when the battery went bad. How old are your batteries?
Old Jul 9, 2010 | 11:14 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Not that old a little over 2.5 years. They have tested good with the hydrometer and hold voltage. I am leaning more towards an iffy ground somewhere. Hopefully someone has a list or diagram of where the grounds are to save time looking or missing one.
Old Jul 13, 2010 | 12:05 AM
bayou barataria
Or a possible short circuit.
Old Jul 13, 2010 | 09:56 AM
buckinut's Avatar
buckinut
had somthing similiar on an 01 Ranger, the pcm burned up in it, would throw theft light..but would try and start...but wouldn't...had to replace pcm, right after, started right up
