Rear 2" block removal
Old Jul 9, 2010 | 09:18 AM
Reid lariat's Avatar
Reid lariat
Any body removed these leaving the truck on the ground. I am thinking of doing this but do not want to bite off more than I can chew.
Old Jul 9, 2010 | 02:19 PM
Twinsdad98's Avatar
Twinsdad98
Are you referring to the spacer blocker block between the axle and leaf springs. Not a big deal to remove since the 4x2's don't have that spacer. However, you'll need new U-bolts since there's not enough threads. The U-bolts are different lengths on the 4x2s and 4x4s
Old Jul 9, 2010 | 05:13 PM
Reid lariat
I found the part # for the new U bolt. It is a light duty U bolt for the 4x2. It sounds like all I need is a jack and a 21mm socket and about 1 hour worth of time.
musickerns
1997 - 2003 F150
Nov 6, 2012 11:15 PM
igotoneforya
Sep 21, 2008 04:20 PM
Boonebird
20
Apr 2, 2008 07:08 PM
njstevens
Feb 25, 2008 10:21 AM
