Random questions
Old Jul 8, 2010 | 03:52 AM
carolinaranger90's Avatar
carolinaranger90
Random questions
ok, so I have a few or so random questions, no desire to waste bandwidth.
I am going to be getting a 4" lift for my 1989 Ford F150 5-spd 4x4.
I do NOT have the proper tools to do the job, and I refuse to risk ruining my truck.
How much have you guys paid to have one installed on your truck?
I am looking to do a 351W/ZFS542 swap into my truck at some point.
I see myself needing the following.
*351W Motor
*ZF Trans
*Applicable ECU
*Proper Sized Drive lines
*Transfer Case Shifter (if my current is not the right size)
Am I missing anything?
Old Jul 8, 2010 | 10:38 AM
nighthawk285's Avatar
nighthawk285
On the lift, I installed my 6" unit out in the street in front of the house with a buddy, but we do install them at my work for about 450 (6 hours labor at $75 an hour shop rate)
As far as the motor/tranny goes. You will also need
*A new starter for a MANUAL transmission (there is a difference in the casting)
*of course, flywheel
*you already have a 5spd in it, so the x-member will be the same
*make sure the ZF is from a 4X4 truck, the tailshaft is different and you have to tear the whole trans down to swap it over
*I didn't need a different shifter with my swap for my transfer case
*Depending on what year you get the engine from, you may need to make some exhaust mods....when I did mine, the angles of the manifolds did not match up to the Y-pipe of the 302.
*Depending on how you want to do you floor, you can either just cut a new hole for the ZF shifter, or go to your local salvage yard and get the right center floor pan
*Clutch pedal w/bracketry.....once you decide if you're going mechanical or hydraulic (I recommend the hydraulic)
*A full set of hand tools, a cherry picker, torque wrench, drill, some know-how, and a flexible body to bust your knuckles with
Old Jul 8, 2010 | 04:57 PM
carolinaranger90
you have opened my eyes man, it's definitely a lot of work, but it should be worth it in the long run, thanks man.
Old Jul 8, 2010 | 05:05 PM
nighthawk285
Yes it is DEFINITELY worth the work.....I've been EXTREMELY happy with my swaps, if you'd like any other info feel free to ask
Old Jul 8, 2010 | 05:06 PM
carolinaranger90
all I need now is a parts truck, and an extra hand for a few days.
Country705
Mar 18, 2013 07:44 PM
Vitaliykit
Oct 29, 2011 12:45 AM
Caveman1113
Feb 4, 2006 03:43 PM
nickmyron
May 28, 2004 11:07 PM
rc351w
Mar 31, 2002 09:09 AM
