Tach works sort of
Old Jul 7, 2010 | 04:51 PM
86.9's Avatar
86.9
Tach works sort of
My tach has gone to not really working very well. It reads idle speed going down the highway. Is that more than likely the sensor or something else?
Jeff
Old Jul 7, 2010 | 05:27 PM
swooshcmk's Avatar
swooshcmk
quite often it's the sensor on top of the IP gear cover. Check it for cracked wires/missing insulation right at the sensor - common failure. If it's oily and the wires are cracked/missing insulation the inside of the sensor is likely damaged.
Old Jul 7, 2010 | 07:52 PM
Sycostang67's Avatar
Sycostang67
Yeah, 99% of the time the sensor is the problem.
Old Jul 8, 2010 | 06:23 PM
royzell's Avatar
royzell
Ditto everyone else. I had the same thing happen on my old truck and a new sensor cured it.
Old Jul 8, 2010 | 08:10 PM
Incenter12's Avatar
Incenter12
Is the sensor readily available?
Old Jul 8, 2010 | 08:59 PM
swooshcmk's Avatar
swooshcmk
Not really, you'll have to get it from a ford stealership for about 80-90 bucks.
Old Jul 9, 2010 | 12:25 AM
oreocreaming's Avatar
oreocreaming
or take your chances at a salvage yard.
Old Jul 9, 2010 | 08:59 AM
86.9's Avatar
86.9
I called the local dealer yesterday and they said it would be $69. Seems a bit ridiculous. I may call International today just for grins. Sometimes they are quite a bit cheaper than Ford,
Jeff
