What is your best solution to 5.4L cooling issues while towing?
Guys,
Been looking through the threads here and haven't come across the answer that I need yet. I have began another thread if anyone cares to read it (https://www.ford-trucks.com/forums/9...-capacity.html), but I'll be more specific here with my questions.
2002, F-250, 5.4L, Ext. cab, 4x4 off-road, 4.11's, 285/75/16 Firestone tires (265/75/16 originally), plow and tow packages.
I had overheating issues last two loads and need to address them. I am not yet convinced this is NOT a gauge or sensor issue...
- If anyone has installed aftermarket coolant temp. gauge and sensor what did you use?
- What is the single-best change you made to your truck to address cooling issues?
- What is the single-best change you made to increase your HP and/or Torque for towing?
I installed an electric fan from a V8 Continental on my DOHC Navigator not for cooling issues but because of noise and available horsepower issues also for clearance at the front of the engine, I like to look at my engine and not see all that clutter in there. Besides that I don't like having that heavy appendage hanging off the front of the water pump that uses the same bearings and seals that my Mark VIII with an electric fan uses. I think that weight will contribute to pump failure sooner than if it was not there.
Does the 2002 f250 5.4 have the terrible ypipe that my excursion had?
I got rid of the restrictors and towing power went up. mpg went up to.
https://www.ford-trucks.com/forums/9...e-upgrade.html
Read this
Read this
Hossrod
05-22-2013 11:23 AM
F90E350
13
03-30-2012 02:10 PM
RUNVS
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
30
06-15-2011 10:17 PM
RUNVS
01-15-2010 01:36 PM
