Does anybody have a source for getting some Stabilizer bar end links. I need them approximately 9" longer than stockers due to my lift. I have a 4" lift installed right now and will be adding 5" to 6" more with the Sky manufacturing shackle and hanger kit? When the shop put the 4" lift on it appears they just modified the original end links by cutting and welding a piece of steel to lengthen the original. I may have to do the same thing but was first seeing if there is a end link which can be bought new basically 9" longer than stock. Thanks for your help in advance. The truck is a 97 F350 4 door powerstroke 4 wheel drive. Thanks again.. Maxx
