Sponsored by: Auxito
How to replace multi function switch
Old Jul 6, 2010 | 07:37 PM
pressureelite's Avatar
pressureelite
Hey guys; On my 2002 supercrew. I have the upper and lower shrouds off and the ignition out, but now I can't seem to get the little plastic clips off multi function switch.
Old Jul 7, 2010 | 03:40 PM
Joe Finn's Avatar
Joe Finn
REMOVAL:
* 1. Disconnect the battery ground cable.
* 2. Remove the ignition switch lock cylinder.
(1) Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
(2) Push the (A) ignition switch lock cylinder release tab with a punch while pulling out the (B) ignition switch lock cylinder.
* 3. If equipped, twist the tilt wheel handle and shank and remove.
* 4. Release the (A) four clips and remove the (B) steering column opening cover.
* 5. Remove the upper and lower steering column shrouds.
(1) Remove the three screws.
(2) Remove the lower steering column shroud.
(3) Remove the upper steering column shroud.
* 6. Remove the multi-function switch.
(1) Remove the two screws.
(2) Disconnect the electrical connectors.
(3) Remove the multi-function switch.
JasonWhite
Feb 11, 2018 03:20 AM
Keith Free
1978 - 1996 Big Bronco
Aug 31, 2016 06:34 PM
PStruwing
15
Nov 9, 2015 06:17 PM
Phil Ayres
Oct 7, 2015 05:44 AM
jjdoyle
Jan 3, 2011 08:38 AM
