How much knock is too much?
1995 F-150, 4.9 six, 5 speed, 2WD, stock tire size, 2.73:1 rear axle, 165K miles, computer shows no codes, odometer checks perfect with mile markers.
Recently bought this truck. First tank of mostly highway driving gave 19.2 mpg with 8 degrees advance. Increased timing to 14 degrees advanced and next tank was 20.6 mpg with similar driving. BUT.... now it knocks some when I take off from rest. With 8 degrees it never knocked at all.
Should I retard the timing to eliminate this knock or is it ok?
He can run premium. But if it still knocks if wont help him. Knocking is the air/fuel mix exploding while the engine is still trying to compress it. It causes the parts of the top of the piston to melt and be blown off.
If you hear any knock immediately left off the gas so that it stops. Then retard your timing, test drive, if it still knocks, then retard more.
add a water /alcohol injection system to it, and boost your mileage way up
up to 50%
Do It Yourself Water Alcohol Methanol Injection | Parts List
http://www.motherearthnews.com/Green...on-System.aspx
http://www.popularhotrodding.com/eng...all/index.html
a simple mist water injection unit can be make cheap and to come on just after idle, with the mister in the top of the air cleaner top/lid,
http://www.wam-a-bam.com/UltraMist.html
![Smilie](images/smilies/happy0161.gif)
montana_highboy
05-25-2008 11:06 PM
dlowenst
18
10-11-2006 10:14 AM
bobsford
03-04-2005 11:55 AM
