Jacking up your truck, tips?
Old Jul 6, 2010 | 04:49 AM
WPlayer's Avatar
WPlayer
Jacking up, as in lifting it to work on, not jacking it up with a baseball bat or tree.
I've lifted and worked on a lot of cars, but not a truck. Any tips, advice, pointers? I don't even know if my jack stands will go high enough.
Thanks!
Old Jul 6, 2010 | 09:43 AM
MattyJessome's Avatar
MattyJessome
Ive always put blocks under my jack to give it some height ...Not the safest thing in the world, but yah gotta do what yah gotta do
Old Jul 6, 2010 | 10:01 AM
70 Bronco TX's Avatar
70 Bronco TX
I'd like to use (and recommend) a bottle jack for the front radius arm if it's a two-wheel drive, but it just doesn't work for my 79 F350. At least not the kind that weren't OEM and have the two upward bent pieces when it contacts the vehicle. I've been reduced to a large floor jack that kind of stinks to carry around, but best I can do.
Old Jul 6, 2010 | 10:06 AM
704 dentside man's Avatar
704 dentside man
I've got a 20" lift Craftsman jack and it does what I need on my rigs up thru the rigs with 37" tires. Since the front is offset, I jack it up on the pumpkin, put one stand out by the spring plate, then go under the spring plate on the other side and put a jack stand underneath once I get to the appropriate height. For the rear, get your jack under the pumpkin and go to town, when you get to height throw the jack stands underneath.
Old Jul 6, 2010 | 01:12 PM
WPlayer's Avatar
WPlayer
Mine is only a 2WD, so I guess I would have to find a way to jack up the front differently than just described. Sounds like you have 4WD.
My jack may only be a 14.5" lift. It's a basic Craftsman that I may need to upgrade.
Old Jul 6, 2010 | 06:41 PM
jsutton's Avatar
jsutton
Mine is a 2wd I put my floor jack under the bolt that runs through the I-beam and Radius arm directly under the spring. I jack it up from there and then put the jack stands under the frame,then remove the jack.
Old Jul 6, 2010 | 08:22 PM
95stepside's Avatar
95stepside
i like to lift my truck by the oilpan, even though most dont reccomend it...
lol jk
sorry i have a completely different front axle i just like telling jokes
Old Jul 6, 2010 | 09:20 PM
bamaf150's Avatar
bamaf150
Whatever you do, dont get under it while its on the jack. Block it up somehow, preferably with jackstands and chock the wheels. Hydraulics can fail. There was a fatality recently where I work, a 60 something year old mechanic, 19 years with the company, crushed by a truck.
Old Jul 6, 2010 | 11:27 PM
myv-879's Avatar
myv-879
Whenever Im changing a tyre on any car or truck I always place the spare wheel under the car so that if the jack fails the car will fall onto the unused wheel and hopefully not fully crush me to death.
Old Jul 6, 2010 | 11:52 PM
fmc400's Avatar
fmc400
MSEE
No, my friend, you don't have to do what you've "got to do" when it involves putting your life at risk.
Some tips:
1. If your jack stands do not go high enough, buy taller jack stands. Never stack anything.
2. As bamaf150 said, never place any part of your body underneath a vehicle that is supported by hydraulics alone.
3. Work on a level surface.
4. Only lift one end at a time. Chock the wheels on the other end.
5. Take 5 extra minutes to think about what you're doing.
Do not take shortcuts when lifting a vehicle. There is absolutely no reason to argue on this one.
Old Jul 7, 2010 | 02:00 AM
WPlayer's Avatar
WPlayer
Thanks, guys! I may have to get some taller jack stands, and likely a taller jack.
Old Aug 21, 2010 | 03:05 PM
MadFrank81's Avatar
MadFrank81
Yes, it will only partially crush you to death so you can enjoy the experience longer! lol
Sorry to resurrect an older thread but I couldn't resist responding to that. That's actually the way I do it too if I only have a jack and no stands for whatever reason.
If anyone cares to respond I had a couple questions about jacking, is it safe to lift by the pumpkin? I know to avoid the edge so the cover doesn't get damaged, but will the pumpkin handle the stress? Also anyone know of a source for small jack stands? I actually need them for my subcompact car, my "regular" stands are just too tall in their shortest position.
Old Aug 21, 2010 | 04:39 PM
bamaf150's Avatar
bamaf150
If you raise the truck by the pumpkin, it will teeter and be unstable, I wouldnt advise it. I would think any auto parts store or tool supply house could get you smaller stands.
dogmantra's Avatar
dogmantra
I upgraded to a mondo floor jack from Harbor Freight. BUT, I kept my small floor jack for working on my tranny. The Big Boy I use everywhere else just won't fit under the trans if I put the trans leveler on it. Gotta use the little floor jack for that.
For road-side use I have a farm jack that I haul around in my lock-box.
Old Aug 22, 2010 | 12:45 AM
MadFrank81's Avatar
MadFrank81
I meant just for lifting it (then putting stands under it). I was just worried that it might bend the case in or something.
