Axle ratios?
Old Jul 5, 2010 | 06:53 PM
Buckeye Rich's Avatar
Buckeye Rich
Axle ratios?
Just wondering if anyone had a chart that showed what axle ratio are based on the door sticker? My "code" is "89" or possibly "B9". I have tried a search but had no luck.
Thanks
Old Jul 5, 2010 | 07:11 PM
mrcassidy95's Avatar
mrcassidy95
there should be an id tag on one of the rearend bolts that has it stamped on it. not many of these old trucks have all the factory parts.....not what you were looking for just my 2 cents..
Cassidy
Old Jul 5, 2010 | 07:32 PM
Buckeye Rich
Yeah, I'll climb under there tomorrow and take a look. I did find a bunch of codes here...
What is my Ford rear end ratio, do I have positraction - Drivetrain.com
It shows a "B9" as a 3.55 LS
Old Jul 5, 2010 | 09:55 PM
Fordzilla80's Avatar
Fordzilla80
What year truck is this for?
Do you have an 8.8 or 9"?
The 3.55 LS ratio seems to be pretty common in the 8.8 rear axle.LS stands for limited slip.I'm pretty sure if the code has a letter and a number,it means the truck is equipped with LS,if the code has two numbers,it's non-LS.
Old Jul 6, 2010 | 04:00 AM
Buckeye Rich
The truck is a 1986 F250 2wd with the 10.25 Sterling.
Old Jul 6, 2010 | 09:30 AM
Franklin2's Avatar
Franklin2
B9= 1985/ 3.55 ratio 8500lb Ford Limited Slip
B9= 1986/ 3.55 ratio 5300lb Ford Limited Slip
Old Jul 6, 2010 | 07:57 PM
Buckeye Rich
Strange that the same code has a different rating from 1 model year to another.
Thanks for the info.
firejack8
2009 - 2014 F150
Feb 19, 2015 03:54 PM
KLEO1480
Mar 2, 2013 06:53 AM
nash22
Oct 12, 2011 07:58 PM
blackbeauty
Dec 1, 2002 08:18 AM
kaution
Oct 18, 2000 10:46 AM
